First post, by AlessandroB
Someone can help me to find all driver for this Pentium4 IBM computer? i not find it. tnks
Reply 1 of 3, by Horun
Here is the IBM driver archive page for NetVista 6792: http://web.archive.org/web/20021030011317/htt … pe=&subtype=Cat
Each link listed gives you the driver page which shows the driver name. From those names you can search here: http://ps-2.kev009.com/pccbbs/netvista_drivers/
example: ADI SoundMAX onboard audio driver, Windows 98SE / Me / 2000 / XP , Signed, 17 Jun 2002, has link: D64Z26US
that takes you here: http://web.archive.org/web/20021107134343/htt … pe=&subtype=Cat
which shows this driver file name: d64z26us.exe and d64z26us.txt which are there, here is the link to the readme.txt:
http://ps-2.kev009.com/pccbbs/netvista_drivers/d64z26us.txt
Reply 3 of 3, by AlessandroB
Wow, there is a lot of link, and lot of hardware/build combination, i need time to check mine chipset,audio chip, ethernet chip and so on… i will ask again if i find some problem. tnks for now
