First post, by mandm_nl
I found this online and it doesn't work (yet). In order to troubleshoot it I need to figure out which motherboard it actually is and hopefully find some information on the switch settings it has as well as other documentation or BIOS images. All I have is the B286-4MF printed on the board.
Right now it has quite an erratic behaviour. Most times it will not POST at all and you will just see ---- on the analyzer. Sometimes it decides it does want to try to boot and it will only give you two POST codes: 12 01. Without knowing the type of BIOS it is difficult to understand what those codes mean. What I do know is that it will also beep by telling you it doesn't see a videocard (even though one is present). In my research I found a couple of BIOSes that have these possible codes. I measured the 5V lines up to the CPU and those look fine and stable.
AMI:
01 NMI is disabled and the i286 register test is about to start
12 64KB base memory test OK
AST:
01 Test CPU registers
12 Test DMA page registers (EGA.VGA vertical retrace failed)
AT&T:
01 CPU test
12 Display controller test
Chips & Technologies:
01 CPU flag register failed
12 Task register failed, Keyboard controller failed
Based on the beep codes it seems reasonable to think that this board has either an AT&T or an AST BIOS. But I might be wrong here.
So, does anyone have any clue to who made this board and perhaps even has some info on the settings?
