First post, by Shiver_169
Hi guys.
It's pleasure to be here, recently return to the world of old computers thanks to a good friend gave me one Vectra VE6 Series 8 with Intel 440BX Chipset, Pentium II 333 Mhz and 64 MB on RAM. This PC had a HDD and the CD Rom Drive broken but hey the most of there is here. Well I get a good IDE CD Rom Drive, 512 MB on Ram, Pentium III SL35E and a SD to IDE Adapter, proceeded to install all components and try install Windows 98 SE with this and I had some problems. First I forgot the limitation of HDD size on this motherboard and try install on 32 GB SD was a problem, reading here and there solve this whith one old 2 GB SD Card, but when try the Installation ir was vert slow. From now on try the Installation many times but 1 hour after cancell the Installation with a 5% of progress in all cases. I was desperate and try everything and in the las moment it occurred to me change the processor for the original Pentium II. And yeeiii the Installation it's completed on 20 min. But now I don't know if the processor Pentium 3 500hz SL35E it's bad or have there are incompatibility with the motherboard and this processor. I buy this processor based on the retroweb site comments based on the model of my Motherboard. And one more thing I want to add is that in the initial BIOS boot screen the Pentium III processor appears as I (unknown) and the speed of this appears correct with 500 Mhz. I apologize for this long history but I try of give some context waiting help more with the solution.
Best Regards for all.
PD: Sorry for my English I'm from México.
