First post, by Ensign Nemo
Hi guys,
Really simple question. I recently got a couple of thin clients for DOS and Windows 98 gaming. For storage, I'm using an IDE cable attached to a SD card adapter. Obviously, thin clients don't leave much room for cable management and I had to leave an IDE cable on top of the heat sink in one of them. I'm just wondering if this could be a hazard and if I should look at putting insulation between them? I'm using dirt cheap cables from AliExpress, so I don't know if they are built as well as the IDE cables back in the the DOS and Windows 98 era.
Thanks in advance.
Reply 1 of 2, by debs3759
Insulation shouldn't be needed (if it is, the CPU is overheating). I would recommend trying to route the cable away from the heatsink though, for airflow purposes.
Reply 2 of 2, by Ensign Nemo
debs3759 wrote on 2022-11-26, 23:19:
I think that would be pretty difficult, as the IDE slot is directly above the heat sink. It's located in the top left of the following image, right below the battery:
