First post, by jaquamala
i have here a AT main board in a unusual red pcb and i need some support for an bios dump or manual? Does anyone know the board or even have information about it? This board is an 586 installed with an pentium 75Mhz cpu and an sis 5501 chipset. This board doesn´t post. I tested with a pc analyzer card. When i power on i get black screen, no beep codes. Nothing. The analyzer card shows me only four "- - - -" on the led segment. The jumper for the cpu settings (after the informations from the silkscreen, white jumper) is correct. For the yellow jumpers i have no suggestions. I think that the main problem is an defect bios chip. The bios chip is an MX28F1000PD. With my TL866II (Xgpro know the model MX28F1000P without an D on the end) can´t read out the chip. It appears fault is a wrong ID. I had tested an known functional cpu, functional ram, and functional chache. All test was made with an new cmos battery. Unfortunately without results. Also i tried a simelar 586 bios without any results. The manufactor could be "Megastar"? The Board has only 2 ide chanals and no fdd chanel. I think for the fdd chanel came this board with this red floppy I/O controller. The main chip is here branded as MEGA. Unter the website "theretroweb.com". i found the collected manufactors "TMC/MyComp/MyNix/Megastar". Thank you for support.
1.84 MiB
1.78 MiB
1.5 MiB
1.52 MiB
Reply 1 of 11, by BitWrangler
It has gemlight vibes to me, and a lot of their later 486 and pentium boards are very poorly documented and models missing. Something between the
https://theretroweb.com/motherboards/s/gemlig … t-cobra-xlp-pci
and
https://theretroweb.com/motherboards/s/gemlight-cobra-xlt
maybe or a parallel undoc cobra model.
Reply 2 of 11, by weedeewee
jaquamala wrote on 2022-12-03, 21:53:
in XGpro disable 'Check ID'
Reading out an eeprom shouldn't be a problem. Programming it might.
Do not ask Why !
Reply 3 of 11, by PC Hoarder Patrol
This link - ftp://retronn.de/driver/Mainboards/Award_BIOS … otherboard.html - lists an SiS 5501/02/03 Chipset (Pentium based m/b); the Mirage M54PS, with a bios string of 2A5ICAM1 which points to Achme as the maker
Reply 4 of 11, by Horun
Wow good find. So it is most likely a MSI (oem?) board according to Achme's old website....
Reply 5 of 11, by dionb
Given how spartan this board is - literally just 5501 chipset and nothing else - the BIOS from another similar 5501 board might well work on it. Only problem is that all other 5501 boards I can find have an additional I/O controller for floppy, serial and parallel. One of their BIOS might work, but no guarantees.
Reply 6 of 11, by Sphere478
Oh wow that it beautiful. Good find.
On the off chance that the bios is a red herring,
Try fpm ram and a pentium 200 non mmx, and a different video card. I had the same problem on another socket 5 ended up solving it. Fingers crossed I also for a time suspected the bios. But it was fine.
Sphere's PCB projects.
Reply 7 of 11, by Horun
If I were to guess, based on the silkscreen of just 75, 90 and 100Mhz (JP7-JP9 which would be 50Mhz, 60Mhz and 66Mhz) that JV1 is Vstd/VRE jumper. JX1 and JX2 are the multiplier jumpers.
The JP7-JP9 set appear correct for P75. If the cpu came with the motherboard then possible JX1 and Jx2 are correct. Looking at JX there are four possibles. 1.5x, 2x, 2.5x and 3x.
If not then try as Spere478 mentioned a P200 non-mmx and see what happens, do not change JP7-JP9.
Also if using a good Diag card be sure to try in both in various PCI and ISA slots, many PCI boards will not output in a ISA slot and some rare boards do not from PCI #1 (SL1).
Reply 8 of 11, by jaquamala
Thank you at all to help me here on this board. I made some progress:
weedeewee wrote on 2022-12-03, 22:54:
Without the marker "Check ID" i could read the chip. Bios attached. Thank you for the tip.
M54PS_(0).zip
65.5 KiB
33 downloads
With the tool MODBIN i could take a peak inside of the bios file. Here i can see some available bios options and also
the bios post string: 05/09/95-SiS-5501-5503-2A5ICAM1-00
47.93 KiB
PC Hoarder Patrol wrote on 2022-12-04, 00:13:
I found the same informations as you. 2A5ICAM1: Mirage M54PS
I have test a other cmos flash chip but no change. There is no different between
the original bios chip and the other. Than could mean that bios is is not the fault. For now.
Sphere478 wrote on 2022-12-04, 01:23:
Unfortunately i don't have a P200 non mmx to my hands. This board came to my without a battery,
but the battery left here some mess on the board. I cleanded it with vinegar and ipa. Around them there are some corroded pads/pins.
Maybe here is the fault and i need here some investigation with the oscilloscope.
1.03 MiB
I found out that randomly every 2-3 times when i power on the board the analyzer card show "07 06" bios post code.
For the Award bios means the "07" after the manual from the analyzer card: -> Verifies CMOS is working correctly. Detects bad battery.
A test with the additional fdd controller make no difference.
1.06 MiB
Reply 9 of 11, by Horun
Have you tried changing the JX1 and JX2 jumpers ? There are only 4 combinations. Are you using a heatsink ?
Reply 10 of 11, by Sphere478
Watch the heat on that cpu. 😀
Reply 11 of 11, by jaquamala
Horun wrote on 2022-12-05, 02:06:
Yes i had tried all possible combinations. I tested also another P 75 Mhz cpu but no change. For this picture i don't used a heatsink but regular yes. I measured with the osci some standard clock signals on the chipset and i found somthing on the rtc clock quartz. Nomally it should runs an 32,768 KHz. I could measure here only 6,5 KHz. I will change the quartz. Hopefully this is the fault.
    44.88 KiB
    776.57 KiB
