First post, by Kouwes
- Member
Hi all,
I have this am486dx-100 system.
Mainboard is a GMB-486SPC V0, S3 Trio 64 PCI, 16MB ram, SB16 CT2230, controller card for serial 1 and FDD.
This is probably not relevant at all, but oh well.
I‘m running DOS 6.22 on it, no windows. Forgot to mention, the 2GB HDD is plugged into the onboard IDE1 connector, the cdrom drive into the IDE2.
Now I had like 577kb of free memory, which isn’t enough for certain games, so I ran memmaker.
Got way more free memory after that but then the cdrom driver wouldn’t load anymore.
I then just restored the autoexec.bat and config.sys which I backed up before running memmaker and rebooted the pc.
Well, still no cdrom????
It isn’t detected in the bios, either. I pulled the jumper on the cdrom drive (was set to master) and rebooted. Cdrom device driver was installed and working - ran memmaker again: same issue.
Any ideas?
Attachments show the autoexec and config before running memmaker.
