Reply 540 of 600, by Nemo1985
After such disaster, a video explaining how to do it would be great if you can record it.
Reply 542 of 600, by ph4nt0m
Sphere478 wrote on 2022-12-12, 02:41:
I can upload a vid of popping the ihs off. It is probably the easiest part of the mod. Everything else is pretty tough.
But you have to do it the way I show.
It has worked for me many times but that isn’t to say that it will work every time. I saw a user on another forum (beginning of this thread) who popped off a bunch of different k6 IHS and like all of them killed the die. Idk what they did, but this hasn’t been my experience on k6-+ chips. You are actually the first in the thread to kill their chip trying to take it apart. Don’t take this as a dis or attack. I’m not trying to do that. You obviously tried hard to avoid this. But let me show the way I do it, and maybe we can avoid it happening again 😀
There is a 100% success chance of removing the heat spreader without killing the die if it's really stuck. Just use 30% hydrochloric acid (HCl). It eats aluminium like a charm. It attacks tin and lead, too, so don't put the whole chip into the acid. A few drops on the heat spreader, wait, wash away, repeat.
My Active Sales on CPU-World
Reply 543 of 600, by biessea
ph4nt0m wrote on 2022-12-13, 12:31:
All of us have Hydrochloric acid at home, yeah.
I am yet angry about my poor amd k6-2+ gone in heaven.
Can't wait to k6-3+ to arrive then and install it and make my Windows 98SE system run again.
What a bad day I had.
Computer lover since 1992.
Love retro-computing, retro-gaming, high-end systems and all about computer-tech.
Love beer, too.
Reply 544 of 600, by Sphere478
What?!! No 🤣.
Did you all see the videos on page 13? Took me a while to convince them to upload:
Don’t miss the Video:
Here are some vids
https://youtu.be/n_ArvBGrD9w
https://youtu.be/pCfdQQtXNF4
https://youtu.be/8__sqFNnpRA
https://youtu.be/ujlXTQWa7R4
https://youtu.be/hDfWu2-epp0
https://youtube.com/shorts/09nsC7tC2-U?feature=share
https://youtube.com/shorts/sfq7EXQe2zI?feature=share
https://youtu.be/xdtEhC8yTTQ
And another:
https://youtu.be/5Aw2U_BZnSk
Here is a video version of the guide. Thanks Bloodem!
Sphere's PCB projects.
Reply 545 of 600, by rasz_pl
your avatar explains everything 😁
so it will eat heat spreader and all the pins/components on top of cpu 😀
Reply 546 of 600, by drosse1meyer
biessea wrote on 2022-12-13, 14:22:
All of us have Hydrochloric acid at home, yeah. […]
it will be okay man. we all make mistakes
Reply 547 of 600, by ph4nt0m
rasz_pl wrote on 2022-12-13, 21:08:
Always looking for new ways around, no matter easy or hard 😀
There are just SMD capacitors which are replaceable in the worst case. In reality, however, there is just some stain to wipe on the soldering. They are ceramic with nickel plating, and nickel reacts very slowly to 30% HCl without heating due to surface passivation. In fact, you can drop the caps straight into the acid and nothing noticeable will happen overnight.
Reply 548 of 600, by Sphere478
Dudes, do not use acid. That’s crazy. Also, you need the heat spreader. The core is waaaay too delicate.
Reply 549 of 600, by drosse1meyer
Sphere478 wrote on 2022-12-14, 16:10:
Dudes, do not use acid. That’s crazy. Also, you need the heat spreader. The core is waaaay to delicate.
personally, i use a 12 gauge shotgun to remove IHS. its super easy. /s
Reply 550 of 600, by ph4nt0m
That thin aluminium heat spreader sucks. Take a decent copper one off an Athlon 64.
Reply 552 of 600, by lawyerpepper
I just bought a three pack of these , so I’ll probably have to try modding one once I get a K6-2+ build stable. I have extremely little soldering experience, so this will give me incentive to learn.
Reply 553 of 600, by Sphere478
Advise practicing on something else. Get help with this one so you don’t mess it up, if you think you aren’t up to it. 😀
Read guide on page 13 and watch the vids.
Reply 554 of 600, by bogdanpaulb
Very nice mod ! I think, maybe you can use the center hole of the razor blade as a reference for how much you have to go in .
Reply 555 of 600, by lawyerpepper
Sphere478 wrote on 2023-02-17, 06:40:
Oh yeah - there will be practice first! OTOH, having someone else do it would spoil the fun, and it’s not as if it’s a Voodoo or something else rare and expensive. I’ve got a few things they should be recapped anyway, so I’ll just start with really basis soldering/unsoldering junk, move on to reasonably sized capacitors, and tackle the CPU once I’m confident.
I followed the Cyrix path back in the 90s, so this will be my first time using a K6. I’ll be taking some time to get the basic build solid before messing with the chip.
Reply 556 of 600, by asdf53
Model: AMD-K6-2E+/350AUZ
Success: No
There was already one failed attempt for this model posted here. But I decided to try it anyway, mine ran stable at 550 MHz and almost stable at 600, so I thought it might be good enough. Sadly no success, black screen at boot, even at 300 MHz.
Delidding the CPU was still useful as I also wanted to replace the thermal compound (mine didn't have anything on it - it was just bare metal on metal), and it definitely helped with stability. Before it would boot at 600 MHz 2.1v, but insta-crashed in any game. Now it is completely stable, running prime95 for an hour with no errors so far. A bigger heatsink and fan are a must, though.
Reply 557 of 600, by asdf53
And this is how my CPU looked after taking the lid off.
I found it very difficult to remove, took me 15 minutes to cut through the corners, then another ten to pop off the lid. It wouldn't come off and I felt a lot of resistance, so I kept cutting into the corners, accidentally cut two of the resistors in half. I soon realized that the die is also glued to the heatspreader, that is why it's so difficult to pop off.
When I finally managed to remove it, it took a chunk of the die with it (visible on the left side). I was 99% sure that I had killed the CPU, but it still works!
To glue the heatspreader back on, I made a thick paste of soldering rosin and isopropyl alcohol, painted it on the remaining glue pads and pressed it together.
Reply 558 of 600, by Nemo1985
Impressive
Reply 559 of 600, by crazytiti
Maybe it's where the supplementary cache is ?
Would explain the non boot.
