First post, by rain
- Member
hi, i searching old at computer cases i found this case but im curious is this AT case. i noticed serial ports on back but not at connector.
-386-4MB-
-386-4MB-
The large rectangular cutout for an input/output shield is the giveaway that this is an ATX case.
Looks like it might be AT compatible, though. You’d just need an ATX I/O shield with only an AT keyboard connector cutout.
This has been discussed before, and you can 3D print this:
Re: ATX I/O shield models for 3D printing
One option would be to get something like this and cut a hole:
https://www.amazon.com/iomesh-black-universal … e/dp/b08nwfqxmj
- Alex
Agree ! Having the Serial/Parallel (and looks like for a scsi) cutouts reminds me of an early AT/ATX combo case from the mid 1990's
and there is no PSU cutout on case
-386-4MB-
rain wrote on 2022-12-16, 06:00:and there is no PSU cutout on case
That's a PSU cutout.
oh thanks ..
-386-4MB-
rain wrote on 2022-12-16, 06:17:oh thanks ..
No worries. 👍
The two marked holes line up with typical AT board holes so I believe this case takes AT as well as ATX motherboards.
I believe I can see an AT PSU inside the case in the first pic too.
Only uncertainty is wether the case can mount an AT switch suitable for mains voltage.
I had a very similar case around 1997 that I bought with a Baby-AT mainboard, it came with a metal shield that had the cutout for the AT keyboard connector only.
Later I upgraded the system with an ATX board and just removed the metal shield.
The AT power switch of the AT PSU could be replaced by a pushbutton switch for ATX mode with the same mounting holes for two screws (those larger ones for 250V~ 1/2A). The plastic AT pushbutton could be put on the new switch easily so you didn´t notice the difference when looking from the outside.
BTW I still have this case, I "downgraded" it a couple of years ago with a FIC VA-503+ and reinstalled the original AT shield. It´s my only permanent Socket 7 / K6-III+ system til today.
Thanks for answers i understand that, ican use it with Socket 7 mobo.
-386-4MB-
