Reply 20 of 22, by unxaix
Hi
I'm interested in one more thing since I do not have much experience with this 16/32 bit world.
This motherboard was designed for a 20 MHz processor by using a 40 MHz quartz. Apart from this quartz there is another one of 14.318 MHz ( which seem to be standard on all 286 motherboards ) and the 32.78 KHz one for the RTC.
On this particular motherboard the rest of the system clocks seems to derived from the 14.318 MHz one so the 40 MHz one looks to be used for the processor only so my question would be, if on another motherboard ( featuring a 16 MHz processor ) , I replace the 32MHz quartz with the 40 MHz one and replace the processor also, would that board potentially function stable with a 20 MHz processor or there may be a risk of instability ?
I'm not sure exactly how the processor cycles are synchronized between these different clocks and if all/almost all of the motherboards back then were implementing the same approach of deriving the bus clock from the 14 MHz one or some of them were using the processor one .
Thank you very much.
