First post, by Half-Saint
- Oldbie
from database: Eizo; Eizo FlexScan F553; EDID eiz0201; HZ 24.5-69.0; VT 55.0-120.0
basically same H and V specs as
EIZO Nanao USA F2-17 nan0401 24.5-69.0 55.0-120.0 from database. which is the USA name for the F553 AFAIK
http://web.archive.org/web/20010418060733/htt … 3/contents.html
http://web.archive.org/web/19990222013241/htt … DUCT/F2-17.html
which should make it std resolution 1024 dots x 768 lines (Possible Max. 1280 x 1024) iirc
Horun wrote on 2023-01-17, 00:36:from database: Eizo; Eizo FlexScan F553; EDID eiz0201; HZ 24.5-69.0; VT 55.0-120.0 basically same H and V specs as EIZO Nanao U […]
Cheers, mate! I connected the monitor to a Windows 10 laptop and it works like a champ at 1024x768 @ 75 Hz :-)The image is crisp and vibrant. Will definitely have to try some games on it later.
