Capacitor Identification
First post, by JayAlien
Whilst removing a FX 5900xt from a tenacious hidden AGP clip, I worked a capacitor loose from the bottom of the board.
I ended up pulling it off completely. Can anyone identify this? If possible a link to mouser or other retailer of a replacement would be appreciated.
    142.29 KiB
386sx25 SBP2 2M
P75(486) SB16 8M
P133 S3 Vir DX A64g 32M
P233MMX R128Pro A64 64M
Pii400 TNT2 Live! 128M
P3-1G V5 M80 256M
P3-1.4G R8500 A1 256M
A3200 9700Pro A2 512M
X6800 X850XT A2ZS 1G
E8600 X1950XTX Xfi 2G
QX9650 3870 Xfi 2G
i7-975 GTX570 Xfi 3GB
Reply 1 of 22, by Shponglefan
It's a surface mount 180uF 16V aluminum polymer capacitor.
You'll want to get a replacement cap with the same specs, but also the same height/width (package size). Then it should be a matter of desoldering the damaged base and soldering the new one in its place.
You also want to be careful when removing the base that you don't accidently rip up the underlying pads. Hence, I would suggest desoldering instead of trying to pry it off.
Edited: Correction to the above, it is a polymer capacitor.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 2 of 22, by JayAlien
Excellent, thanks for the info, I think this is just the ticket?
https://www.amazon.com/Solid-Capacitor-180uF- … ps%2C110&sr=8-5
I'll be thinking of my mistake tonight, whilst I'm behind closed eyelids.
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
QX9650 3870 Xfi 2G
Reply 4 of 22, by JayAlien
Ah Polymer, got it.
Found it on mouser:
https://www.mouser.com/ProductDetail/667-16SVP180MX
does this look correct?
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
QX9650 3870 Xfi 2G
Reply 5 of 22, by Shponglefan
JayAlien wrote on 2023-02-08, 00:48:
Ah Polymer, got it. […]
Ah Polymer, got it.
Found it on mouser:
That looks like it would work, but you will want to double check the package size (diameter & length) to match the one you are replacing.
Panasonic is a good brand for caps, so it should be reliable.
Reply 6 of 22, by JayAlien
Thank you for the reminder, the one I linked was in fact the wrong length and diameter. I found the correct ones and got a few ordered. (Why am I unable to buy a single capacitor and that I always buy a few extra 'just in case'?)
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
QX9650 3870 Xfi 2G
Reply 8 of 22, by Shponglefan
Nexxen wrote on 2023-02-08, 02:23:
Why does size matter?
It just ensures proper fit.
In some cases size variation won't matter depending on the board / pad layout. But in my experience it's easier to just match components accordingly.
Reply 9 of 22, by JayAlien
Well I got the new cap and replaced it. Continuity test with a multimeter shows good connections from the pads either side of the new cap, but still cant get the system to even power on with this card installed (System works with a Radeon 9700).
I'm not getting a continuity test across some of the other caps towards the top of the board. I think this card may be toast, or beyond my ability to repair. 🙁
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
QX9650 3870 Xfi 2G
Reply 11 of 22, by JayAlien
Of course, here it is.
Ah, I had to lower the resolution a little for the 2mb limit
EDIT - I tried this GPU in another P4 system and same behavior, a momentary pulse of all the fans but no boot. Putting the Radeon 9700 in this second system booted just fine.
    910.79 KiB
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
QX9650 3870 Xfi 2G
Reply 13 of 22, by bogdanpaulb
By the looks of it, those 2 purple caps are on the 12V input for the vrm from the molex connector . If you have a good PSU and the video card is fine, it should boot/work without both of them. Use a multimeter and check for continuity between(without system power) the yellow molex wire (12V) and the unmarked pins of the caps(they have 2 pins one is not marked an the other is marked by the purple shape from the cap. Then check so you don't have continuity between the 2 pins of the cap, then with the multimeter set to voltage mode and system powered on check again if you have 12V between the 2 pins of the caps(be careful not to short something).
Reply 16 of 22, by Nexxen
bogdanpaulb wrote on 2023-02-15, 13:41:
I don't know about the FX5900XT, but my FX5900 Ultra does not display anything without the molex connector plugged in.
I thought it could be. My Radeons do. Well, wouldn't be a funny troubleshooting job otherwise 😀
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 17 of 22, by JayAlien
Thanks for the advice so far
I get continuity between the yellow molex and both sides of both the purple caps.
I do have continuity
So I have a short perhaps?
I haven't tested for 12v across the caps yet, but if I have a short not going to see a voltage across the caps....
EDIT - I have continuity between the yellow molex and both black cables. I've got a short.
EDIT 2 - I removed the cap I soldered on in case I'd created a solder bridge, and cleaned the pads. With the cap removed I still have continuity both across the empty pads and across black/yellow at the molex connector.
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
QX9650 3870 Xfi 2G
Reply 18 of 22, by bogdanpaulb
Post a high res pic with the area selected (front and back).
    914.55 KiB
Reply 19 of 22, by JayAlien
Thanks for looking, here are the images
    1.86 MiB
    1.84 MiB
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
QX9650 3870 Xfi 2G
