First post, by vacatedboat
This is my first battery corrosion removal process of a 386 board. Just after feedback. The underside of the board had no damage.
I plan to re tin and then coat with either green nail polish or try and get formal coating.
Thanks for looking
Reply 1 of 4, by Horun
The traces look OK so maybe was got lucky and no real damage. I would test the board as-is to make sure before coating it....
Reply 2 of 4, by majestyk
Looks like the "printed fuse" might have lost contact at the center (or could do so soon) due to the corrosion and the cleaning process. Maybe it´s safer to solder a new "regular" 3A pico-fuse in that place.
Reply 4 of 4, by majestyk
It´s this one:
16.41 KiB
It´was designed for a defined copper thickness, that is probably reduced now. If you tin it, it gets thicker, but electrically undefined. It might blow too early or not at all when there´s a short at the keyboard connector (in the kb-cable, the kb itself or some other device connected to it).
