First post, by vstrakh
I had this sound card in the pile of old scrap for some time, but never really tested it.
Under close inspection it appeared suspiciously scratched. I've touched it with IPA, and the label faded away.
The attachment fake1.jpeg is no longer available
Trying to identify what's actually was sold under the name of Yamaha I found images of cards that appear similarly sanded down and relabeled.
The attachment fake2.jpg is no longer available
The attachment fake3.jpg is no longer available
Any idea what's that really is? Or is it a sound chip at all?
I could imagine faking the cache chips on early motherboards, but this one looks too badly executed.
Reply 1 of 10, by CharlieFoxtrot
That indeed doesn’t look like Yamaha chip just based on size and shape.
I do think it’s some kind of audio chip and that is a legit cheapo sound card. Based on the shape of the chip, it could be some Opti chip or even just Analog Devices Soundport/etc. Windows Sound System chip.
It is quite interesting that they bother with these kind of fakes, YMF-7xx sound cards aren’t that expensive after all.
Reply 2 of 10, by GigAHerZ
Those tiny-flimsy PCBs of those sound cards look like something made with Crystal chips... Never seen such cards with YMF chips.
Reply 3 of 10, by vstrakh
GigAHerZ wrote on 2023-03-10, 15:21:
Found the Crystal card photo with exactly the same pcb. Yep, that's relabeled Crystal.
The attachment crystal_card.jpg is no longer available
Reply 5 of 10, by bogdanpaulb
This is the same thing as they did later with C-MEDIA (CMI) chips and called them Yamaha xg724 ( the chips where fake marked like this one , but the actual size was that of the CMI) . Even the cd driver was Yamaha branded , but the drivers from it were working on CMI cards and the ones from CMI cards were working on them , they only difference was how the device was listed in device manager . I had a card like this back in the day and took me a while to understand why it was not working with the original ymf724 drivers . Anyone knows this soundcard? .
Reply 6 of 10, by vstrakh
The attachment ItsaFake.jpg is no longer available
So, first trying the UNISOUND on it for general detection. The card is found and configured. The report is shown as:
The attachment unisound_report.jpg is no longer available
The string read from EEPROM is "[CDC4835] OPL3-SAx" is meant to convince inexperienced user he got the Yamaha.
But see the last line - "Crystal Mixer ...". It's Crystal all right, with edited EEPROM content, and this ugly FM synthesis of CX4235 (listening to Dyna Blaster).
For the sake of test completeness I've ran the Yamaha utilities:
Reply 8 of 10, by Tiido
Yeah, these are Crystal based cards. I have seen them on ebay few times and I could immediately tell they got the wrong pinout and connectivity but it happened to match that of Crystal parts which use I2C EEPROM over µW and single 16.9344MHz crystal rather than 33.8688+24.576MHz(although 24MHz one is missing on the lowest end cards, which produces some problems like wrong 32 and 48KHz sample rate).
Reply 9 of 10, by Konrad Essen
vstrakh wrote on 2023-03-11, 07:31:
So, first trying the UNISOUND on it for general detection. The card is found and configured. The report is shown as: […]
I have the same sound card! I've been looking for drivers for it for two weeks now. I tried installing Crystal and opl3-sax drivers, but nothing worked. The Windows 98 device manager still shows four unknown devices! Which drivers should I install?
Reply 10 of 10, by vstrakh
I didn't use it with Windows.
For the DOS it was enough for me the card is compatible with Sound Blaster Pro. So you can use UNISOUND and set the BLASTER environment variable accordingly. Then each game would either autodetect the card from BLASTER variable, or would need explicit configuration using game's own setup/install utility.
Although, this page https://www.dosdays.co.uk/topics/retro_review … d_sound_pt2.php say Crystal 423X drivers were called "CrystalWare", and there's an example of the setup.
Vogons Driver Library has a section for Crystal chips: https://vogonsdrivers.com/index.php?catid=69&menustate=61,53
