Reply 48460 of 56748, by Vynix
Just nabbed a 12x SCSI CD-ROM drive for my "7500 Fauxsammer" project (basically, a Power Mac 7500 with a G3 in it), I would've preferred to find one of the 24x models but none turned up so far ¯\_(ツ)_/¯
Oh and while I was checking the 7500/G3 up to see if it still worked, I went to format a zip disk, and well, this happened:
The attachment 5af3b688-ae04-45d5-8672-5048b0493a92photo.jpeg is no longer available
This machine is a weird beast sometimes... Now I just need to find a proper monitor (so I can put back my M1212 monitor with the LC II it came with) and a zip drive bezel for it and maybe some other stuff... And maybe it could finally be called complete.
Reply 48461 of 56748, by RandomStranger
I P4 PC in a decent looking case.
The attachment IMG_20230313_185234.jpg is no longer available
It supposed to work, I don't care much if it does. I only bought it because of the case. It's only a little bigger than my W98BOX, which is very small, allows full-height expansion cards, has room for 2×2.5" + 2×3.5" + 1×5.25" drives. A little disappointing, I expected 4×3.5" since I got the case to build a NAS into it.
The attachment IMG_20230313_185320.jpg is no longer available
The attachment IMG_20230313_185340.jpg is no longer available
What else I get out of it, a Mercury P4VM800M board with a 2.8GHz Pentium 4, I think 512MB RAM, an 80GB IDE HDD, a Samsung IDE optical drive and a very interesting SFX PSU. I don't know anything about the brand, it has no SATA power or PCI-e power connector, but has 4+4 pin CPU power connector, it also has decent specs at least on paper.
The attachment IMG_20230313_185730.jpg is no longer available
Otherwise the PC was shipped with a lot of free dust and dead insects inside.
Reply 48462 of 56748, by BitWrangler
Case is kinda awesome, like you've got the front of a spaceship crashing through your wall or something. Looks kinda like it was for HTPC market.
The PSU, I'd have to judge it on weight. The wire thickness doesn't look too bad though. If it was a real light one it would go in the "PSUs to use if other mistrusted hardware is in danger of blowing them up" or PSUs for stealing spare connectors off, pile, if it had some reasonable weight, okay looking sinks and caps and tested good, it would get rated at 300W in my head and passed for general unexciting machines. The 400 headline watts and partnumber with 350 in it isn't very encouraging though.
Reply 48463 of 56748, by BitWrangler
ediflorianUS wrote on 2023-03-13, 11:20:
Bitwrangler , what kind of PC Chips board? 950 sk478? - mine is driving me up the wazooo , keeps beeping to me, and I don't know what to do.
Mine would be a PIII/Celeron one, don't know much about P4 PCChips, you might find more about the ECS equivalent. Beeping but won't post is commonly mem or video errors, beeping while it's running is probably hardware monitoring alarms going off for temperature or low/high voltage
Reply 48464 of 56748, by TheAbandonwareGuy
RandomStranger wrote on 2023-03-13, 18:24:
I P4 PC in a decent looking case. […]
Those cheap off brand fire supplies power supplies are garbage.
I had a Sharktech 500w PSU melt the cord plugged into it several years ago.
I only use name brand or OEM PSUs now. I'd rather use 20 year old vintage name brand than poorly designed, no safety features chinesium crap.
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
Reply 48466 of 56748, by AlessandroB
CrFr wrote on 2023-03-09, 20:10:
Bought this Compaq V50 CRT monitor. It is (was) in excellent shape. Of course the bezel had to crack during shipping. Other than […]
Bought this Compaq V50 CRT monitor. It is (was) in excellent shape. Of course the bezel had to crack during shipping. Other than that, it looks almost like new. Managed to inject some glue in the crack and then push it back together. It looks fairly good now. Interior is very clean. I took it apart to clean it, but there was no need for it. Only the anode cable surroundings have some black fine dust, other areas are just spotless. It is made in 1997, but I think it will look nice paired with my 486 Prolinea 😀 Paid 35€ + shipping.
edit: https://web.archive.org/web/19961225084659/ht … ors/sumv50.html
How to close the gap between the two part glued? i’m looking for the same for my monitor
Reply 48467 of 56748, by PD2JK
AlessandroB wrote on 2023-03-13, 20:03:
PD2JK wrote on 2023-03-10, 16:47:
Last purchase for this year. I promise. Really.
What is???
It's a Roland RAP-10/AT. General MIDI card and non-SB compatible 16 bit sound, as vogoner dion_b told me.
I thought it was midi-only.
Reply 48468 of 56748, by Shponglefan
PD2JK wrote on 2023-03-13, 20:22:
Yup, RAP-10 does digital audio in addition to MIDI.
I think some folks confuse it with the Roland SCC-1 which is MIDI only.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 48469 of 56748, by ODwilly
TheAbandonwareGuy wrote on 2023-03-13, 19:21:
Those cheap off brand fire supplies power supplies are garbage. […]
I bought my step-brother a Apevia "Beast Power" 800watt for $20 a few years ago. Did the exact same thing as your Sharktech after two years of use ! It didn't kill any parts but the power cord was a sight to behold.
Reply 48470 of 56748, by kixs
Shponglefan wrote on 2023-03-13, 20:27:
But should mainly be used as GM only anyways 😉
Here is something new in my collection 😁
Visit my AmiBay items for sale (updated: 2025-03-14). I also take requests 😉
Reply 48471 of 56748, by ediflorianUS
It's not from GPU/mem/cpu and it's a no-post. it's something on MB that I am unable to identify , I did recap the board , had a few caps missing , still no go. beeps only. BTW w8ting for new stash(lot) to arrive.
L.E. Spring Machintosh (lot/stash) is here....!!!!....
My 80486-S i66 Project
Reply 48473 of 56748, by CrFr
AlessandroB wrote on 2023-03-13, 20:05:
I wedged the crack more open with couple of toothpicks, then added glue, removed the picks, and pushed it tightly together with a woodworking clamp like this. Left it to cure for about 12 hours with the clamp.
The glue I used was Uhu Max Repair Power.
Reply 48474 of 56748, by PD2JK
It was cheap. So...
InWin Q500A bigtower
Intel AL440LX with sound, no GM chip, can this be modded onto the board?
P2 233
20GB Barracuda II
Diamond Viper V330 PCI (Riva 128)
The attachment DSC_3098.JPG is no longer available
Reply 48475 of 56748, by Kahenraz
There are usually additional supporting capacitors and resistors that are missing in addition to these onboard sound chips. And there's no telling what the values are for any of these other components.
Reply 48476 of 56748, by Ozzuneoj
Oh boy... what did I do to myself this time? Just a week or two ago we had a discussion here regarding DX10 era cards starting to become scarce and maybe having some niche use cases in the near future. Just a few days later, what do I find?
The attachment yikes1.jpg is no longer available
Uhg... why why why. I could have just bought the two FX 5950 Ultras and been on my way, but no. These were sold as scrap, and I'm sure would have ended up as such eventually. There were even more 8800GT\9800GT cards and many more DX10-DX11 era cards without their coolers attached (and the seller said they were already thrown away), but the weight and size of this lot was getting absurd as it was, so I had to let them go.
They were apparently recently pulled from systems, so they have not been thrashing around in a scrap heap for a 15-20 years. I fully expected some damage, and there is some, but it isn't anywhere near as bad as I thought it'd be. I would say only 2-3 have enough SMD damage to be hopeless without a ton of work. Some have no SMD damage, others just have 1-3 components chipped off... I'm really hoping they're just EMI filters that aren't needed for operation. Until I start testing them out I have no idea if even a single one works, but I have a feeling that most of them will... even if they require a tiny bit of soldering work to get to that point. And I did specifically grab an extra 8800GTX that had been stripped of it's cooler, simply to use as a parts board for the others... or if it's in better shape, maybe just move one of the coolers onto it and use one of the others as a parts board.
What is in the lot:
3x MSI 8800GTX
2x EVGA 9800GTX+
4x PNY GTX 285
2x PNY 8800GTX
1x PNY 9800 GX2 (what a monster of a card! It's built like a solid metal brick. Absolutely no way these can get SMD damage!)
2x EVGA GTX 580
ASUS GTX 1050 2GB
2x Nvidia OEM Geforce FX 5950 Ultra (amazingly, at a quick glance they appear to be undamaged except for one bent cap on the top)
1x ATI All In Wonder 9700 Pro 128MB (looks like it got a bit hot at some point, not expecting it to work)
3x XFX 6800 XTreme 256MB (all three have bad caps but they are through-hole and shouldn't be hard to replace... one card is still in the plastic!)
Bare Cards:
1x PNY 8800GTX
1x Quadro FX 1000 (NV30GL; underclocked FX 5800)
1x Visiontek Geforce 3 (original)
1x All in Wonder 9700 Pro 128MB (completely different layout than the other, but marked the same)
1x ASUS 9980 Ultra FX 5950 Ultra (seems basically intact! Just needs cooling)
I probably won't go too crazy with this stuff right now, but I'll do some testing, mark which ones work, what repairs the others need and just tinker with them as time allows in the future. If the GTX 1050 works it will probably end up in some older Optiplex which I can resell locally as an entry level gaming PC and then pay off the entire cost of this lot... yay. 😁
Finally, I also got this in the mail today. Got it for a very fair price considering how scarce they are.
IBM\Tecmar ARPA PC sound card (~1989)
The attachment Tecmar ARPA PC.jpg is no longer available
I'm really looking forward to tinkering with it! I believe this is now the oldest PC sound card I own. Based on some discussions online I guess with the right drivers it will do something not entirely unlike Adlib and Sound Blaster emulation. Neat. 😁
Reply 48477 of 56748, by TrashPanda
9800GX2 ..nice card if it works !
Reply 48478 of 56748, by Ozzuneoj
TrashPanda wrote on 2023-03-15, 04:50:
Yeah, I haven't used a GX2\X2 card of any kind since my brief stint with a 7950GX2 back in 2006, so I am interested to try it out. I was really happy to see that it is entirely encased in metal and plastic. If it isn't defective it should work fine. Most cards of this era are heavy and have all those fragile components exposed on the back. Not this thing! 😁
Reply 48479 of 56748, by TheAbandonwareGuy
Ozzuneoj wrote on 2023-03-15, 05:02:
Yeah, I haven't used a GX2 of any kind since my brief stint with a 7950GX2 back in 2006, so I am interested to try it out. I was really happy to see that it is entirely encased in metal and plastic. If it isn't defective it should work fine. Most cards of this era are heavy and have all those fragile components exposed on the back. Not this thing! 😁
The GX2 does have a weird habit of the secondary (upper) DVI port dying though. IIRC the heat from the heatsink blower setup bakes the signal controller for that port. The other 2 ports on the main PCB don't have that issue. 9800GX2 is kind of different from other dual GPU cards in that its 2 PCBs sandwiched together with a beefy SLI interconnect: https://www.techpowerup.com/50961/nvidia-gefo … dismantled?cp=2
GTX 295, GTX 590, and GTX 690 along with all AMD Dual GPU cards are 2 chips on a single PCB.
Monsterous card, I daily drove one for a couple of months once when my GTX 470 died (which was itself due to my 780Ti dying which I later brought back to life). Played War Thunder, Insurgency and CSGO fine in 2018 🤣
EDIT: Also ffs when did these become worth $80 USD? I paid $20 shipped for mine like 5 years ago.
