First post, by caejr73
I bought an ATX 20 Pin to AT P8 P9 power supply adapter cable that has the two wires with the female spade connectors at the end to connect to an AT power switch. The power switch I plan to use has 4 male spade connectors underneath to connect to. I did test for continuity on the power switch and there is continuity on each side of the switch when I press the button in from front to back. My question is can I use these types of switches with these types of adapters and if so does it matter how I connect it as long as I choose a side? Does ground go in the front or back male spade connector?
Any feedback from an expert appreciated!
Reply 1 of 4, by majestyk
When there´s only continuity as long as you keep the button pressed, you cannot use the switch.
What you need is some kind of toggle switch.
Reply 2 of 4, by Boohyaka
My understanding is that he's going to use an AT style switch that has a toggle position, so it should be fine. I did this myself in the past with an ATX-AT adapter inside an AT case. You can connect the two prongs of the adapter to a pair of spades of the AT switch, you don't need all 4 connected.
https://web.archive.org/web/20180106025824/ww … tsSwitch-c.html
Either connect your adapter to what is labelled black+brown, or white+blue.
The attachment AT Switch pinout.jpg is no longer available
Reply 3 of 4, by caejr73
Thanks Boohyaka for the assist. I hooked it up (brown and Black) and it works perfectly. New whisper quiet ATX PSU in my 486! Thanks Again!
