First post, by Rikintosh
- Member
I have a small MSI Mega PC computer, which has a single PCI slot, and only IDE connections, I want to use a 1TB HDD on it, and I can't use a sata pci controller card, as that would use the only pci slot it has , I want to use the pci for a sound blaster, so the solution I found was the sata ide adapter. All are Chinese, they don't have a brand or model, I believe they can only be recognized/differentiated through photos or the model of the controller chip. I want to use the best I can find, unfortunately I don't have enough money to buy all the models I found in my country, and test them to find the model with the best performance.
Any suggestion?
Take a look at my blog: http://rikintosh.blogspot.com
My Youtube channel: https://www.youtube.com/channel/UCfRUbxkBmEihBEkIK32Hilg
