dionb wrote on 2023-04-12, 13:05:This sounds very odd indeed. The Aptiva 2158 was a uATX system, so an ATX board wouldn't fit, nor would a babyAT board. […]
Ahrle wrote on 2023-04-12, 11:39:[...] […]
Interesting 😮 That should put the IBM even further ahead, with both chipset, cpu speed, ram type and gpu in favor...
At least POST says "K6-II @400MHz" or so, unsure what cpu truly lurks inside. Googled the exposed sb82371sb chip to find 430vx, but now realize it's just a pci bus...
I think the board's Asus P/I-P55T2P4, but googling it returns an AT board, while mine is ATX.
Apologies for vague infos, will get access to PCs during weekend again 😀
There is an ATX version of the P55T2P4 (called XP55T2P4), but that's full ATX, not uATX. Also, both P55T2P5 and XP55T2P4 have i430HX chipset, not i430VX.
I think you need to see what is really in the system as this doesn't compute.
I can turn on and off both L1 and L2 in BIOS. They're both on, but as you're asking, I can't tell if there's any actual L2 mounted (assume the bios option would be grey then?). How can one verify it's working?
(It's an Aptiva 2158, there's a huge manual online, if helpful)
Cachechk. Simple DOS tool, just run it and it tells you how much cache you have and what it's caching.
Anyway, the 6x multiplier is a non-issue, AMD re-used the 2x multiplier on later K6-2 CPUs (CXT, Chomper eXTended - K6-2 from 350 onwards basically) , so if the system can support a Pentium 120/133, it can give the correct multiplier for 6x.
Finally home, thanks for bearing with me 😁
The mysterious Asus board is indeed P/I-XP55T2P4. My bad just googling the PCIset. i430HX, standard ATX it is =)
IBM's a different story. It houses an ALi M1542/M1543 combo, which was the baby-AT tailored version of Aladdin V (V+). L2 is unfortunately onboard, so probably no hope upgrading that, is there? Board is Acer V72MA.
Did the Cachechk however:
This machine seems to have both L1 and L2 cache. [read]
L1 cache is 32KB --1627.0 MB/s 0.6 ns/byte (494%) (290%) 1.5 clks
L2 cache is 512KB --560.2 MB/s 1.9 ns/byte (170%) (100%) 4.5 clks
Main memory speed --329.1 MB/s 3.2 ns/byte (100%) [read] 7.6 clks
Effective RAM access time (read) is 12ns (a RAM bank is 4 bytes wide).
Effective RAM access time (write) is 45ns (a RAM bank is 4 bytes wide).
"AuthenticAMD" 486 Clocked at 626.4 MHz, Cache ENABLED.
Could test more thoroughly, probably a bench between the two? Asus lacks USB, CD-ROM and floppy though (brand new case since I had nothing to put it in), stuff takes time unfortunately.
gaffa2002 wrote on 2023-04-12, 15:09:
Ahrle wrote on 2023-04-11, 04:50:
😁 With IBM's own drivers the game looked like CAD... Now ATI's latest are installed though, and DX9C.
Have you tried the ATI drivers I suggested? The latest ones are really bad, trust me...
Unsure, can give it a shot, thanks 😀
Main of 59 desktops: IBM PC300PL 6862 | Slot 1 PIII-750 | 256MB PC100 ECC | Diamond FireGL 1000 | CT6670 V2 8MB | AWE64 | MT-32 & SC55 MK1 | Win ME
I may have problems, but is nice being set for life
