First post, by tomcattech
After banging my head on the wall playing with jumper settings everywhere I've finally got a p3 1.1 working on a Slot 1 using a MSI Socket 370 to Slot 1 converter.
The motherboard Asus P2B has an old school temp sensor and I want to get as close as I can to a real CPU temp without screwing up all the hard work I just did.
Any ideas on placement?
    282.04 KiB
    201.31 KiB
Reply 1 of 4, by PARKE
There are thermistor cables on the market with tips & attachement cables that are fine enough to slip under the cpu. Some Thermaltake models used to come with such.
https://www.overclockers.com/thermaltake-volcano-9/
Reply 2 of 4, by tomcattech
So there seems to be some open areas on top of the processor outside of the fan that work well per the red areas in the pic.
Obviously the temp readings there won't be perfect but should be close.
Any ideas on how to safely attach the sensor to the top of the processor?
Thanks!
Reply 3 of 4, by bogdanpaulb
if you don't mind, you can use some type of thermal glue: https://ro.farnell.com/mg-chemicals/946 ... price=true and place the sensor as near as you can, maybe on the side area of the heat sink that touches the cpu, as close to the 'middle' and as 'near' to the cpu die as possible.
