First post, by W.x.
What's manufactured date of this HDD? Datecode is 9941
The problem is, Seagate started to use fiscal 4-digis or 5-digit code, somewhere around 2000, but I don't know at which point.
So it can be 41th week of 1999, or 1998-07-22 if it's fiscal year date code.
Fiscal datecode:
Date Code Shape: YYWD or YYWWD
* YY: fiscal year, beginning on the
1st Saturday of July YY-1
* W[1-9] or WW[10-52]: fiscal weeks
from 1st Saturday of July YY-1
* D: days from the beginning of week
WW (weeks run from Sat to Fri)
Reply 1 of 4, by MMaximus
Sometimes it's tricky to find out from the label, so I look on the underside of the HDD to check for any datecodes on the ICs. If you're luck this should roughly give you the manufacturing year of the drive...
Hard Disk Sounds
Reply 3 of 4, by W.x.
I've found good article, that brings more light into this mystery.
https://www.os2museum.com/wp/decoding-seagate-date-codes/
The bad news is, that even the author doesn't know when Seagate turned into fiscal datecode on consumer hard drives. He only approximates it - somewhere in FY98 (Fiscal year 1998, that means 99ww datecode ). Problem is, I've never seen 5-digit datecode on 99' Seagate Medalist drive. Only 4 digit ones. That implicates, that they are in YYWW format, because for fiscal year format, you need also 5digit code to cover whole year, and 5-digit code should be much more often seen than 4-digit one (as they need to cover 10-55 weeks, instead only 0-9, which is 5 times longer time period)
I've also found something that contradicts that
this is the drive with 05097 datecode. That mean, 9th week is in "09" (not 9) expression, making it 5-digit code, while according definition, it should be 4 digit code. (as for 1-9 weeks, W, not WW should be used). Maybe, it can be both? That would be even more confusing.
https://www.donordrives.com/st330015a-5jx-wu- … hard-drive.html
    143.27 KiB
Reply 4 of 4, by Horun
Based on 9941 and the January 1999 manual for the drive: https://www.seagate.com/support/disc/manuals/ … si/17240pma.pdf
I say it was made in week 41 of 1999....
