Pci cards not fit completely
Reply 20 of 39, by OldWingCommander
dormcat wrote on 2023-06-30, 19:13:
Looks like the keyboard DIN-5 connector is too far from the back plate of the case. I suspect the bottom of the bracket hits the […]
cydvog wrote on 2023-06-30, 15:25:
No its not, see pic
cydvog wrote on 2023-06-30, 17:15:
Yes motherboard has a tray and its fit correct
Looks like the keyboard DIN-5 connector is too far from the back plate of the case. I suspect the bottom of the bracket hits the floor plate (the yellow line) instead of the slot opening.
More importantly, why does it look like the corner motherboard screw hole is not aligned to a screw mount point and why is there no screw?
Reply 21 of 39, by Gmlb256
OldWingCommander wrote on 2023-06-30, 20:50:
No its not, see pic
There is another thing that I have noticed with that picture, apparently it isn't a Slot 1 motherboard and lacks the ATX connector that was displayed in the first picture.
Perhaps the OP is testing with a different motherboard to see if everything can fit on the AT computer case without issues?
Reply 22 of 39, by dormcat
Gmlb256 wrote on 2023-06-30, 21:14:
There is another thing that I have noticed with the second picture, apparently it isn't a Slot 1 motherboard and lacks the ATX connector that was displayed in the first picture.
Perhaps the OP is testing with a different motherboard to see if it can fit on the AT computer case without issues?
I was typing and you beat me to it. 😅 The #1 post had a Slot 1 Pentium 2, both AT and ATX connectors, and SDRAM; the #13 post had EDO RAM and AT only.
Reply 23 of 39, by andre_6
Potential AT vs ATX mix ups and issues aside in this scenario, I also had this kind of problem.
Even in an apparently lauded ATX case like the Inwin A500 I've had to compensate for some quirks of the removable tray where the motherboard sits. Even though the standoffs were all the same height, for some reason the expansion cards were not going in fully in the board. I then noticed that the board was slanted just enough to make it low enough on the ports' side for the cards to not go all the way.
I had to slightly elevate all of the standoffs closest to the ports' side to make the board level throughout when screwed on. At first I thought the L shaped tray was bent in some way but nope, and also the standoffs are all at the same height between themselves. I still don't know why this happened.
Here's hoping that the OP's just mixed up AT vs. ATX. The case seems well built anyway. The Late AT/early ATX hardware era can be confusing...
Reply 24 of 39, by Horun
In first picture the card is NOT properly seated in the PCI slot, the back is not fully down as others mentioned. Looking close at the slot it is obvious, see picture below.
Also: rare but I have stumbled on a few brackets that are about 1/16" or so above the case back when properly seated, for those I barely bend the Tang down so it fits a bit closer....
    225.45 KiB
Reply 26 of 39, by weedeewee
the bottom of the card plate should slide into the slit of the mainboardcarrier.
    37.24 KiB
    this slides into that.
Do not ask Why !
Reply 28 of 39, by weedeewee
cydvog wrote on 2023-07-02, 13:06:
weedeewee wrote on 2023-07-02, 12:33:
Its entering but not completely
Show us.
Take a photo that shows card in slit of mainboardcarrier with and without the mainboard,
with slit in mainboardcarrier and top of card visible in both photos.
Do not ask Why !
Reply 29 of 39, by cydvog
My english not so well im attached pictures
Reply 30 of 39, by weedeewee
ok, close but no cigar.
I want you to take a photo of the card in the computer case with and without the mainboard in place, and showing both top of card & slit in mainboardcarrier in which card is situated.
You will have to take the photo at an angle. not straight from top.
Do not ask Why !
Reply 31 of 39, by cydvog
weedeewee wrote on 2023-07-02, 13:25:
Can you add example photos i didnt unterstand ::))
Reply 32 of 39, by weedeewee
cydvog wrote on 2023-07-02, 13:31:
Sorry, I can not.
Do not ask Why !
Reply 33 of 39, by cydvog
Here is picture tray with motherboard card is completely fit. But after put tray in it back to case its not fit.
Reply 34 of 39, by weedeewee
cydvog wrote on 2023-07-02, 13:41:
the standoffs you are using to support your mainboard are too short.
put mainboard back in case and take photo like in this post. Re: Pci cards not fit completely
keyboard connector should be clearly visible !
Do not ask Why !
Reply 35 of 39, by cydvog
weedeewee wrote on 2023-07-02, 13:44:
the standoffs you are using to support your mainboard are too short. […]
Here is , im suspecting standofss like you
Reply 36 of 39, by weedeewee
Measure the standoffs Re: Pci cards not fit completely
like this
    77.1 KiB
    standoff measurement 6.5mm
Do not ask Why !
Reply 38 of 39, by weedeewee
mine are 6.5mm
Do not ask Why !
