Reply 24680 of 27786, by rasz_pl
Trashbytes wrote on 2023-07-16, 01:59:Unless you are buying cheap nasty QLC drives, most modern drives are using MLC or TLC with massive SDram caches with crazy TBW figures of 1,200 Terrabytes*
For a 1TB drive, so a modern fancy drive with cache and best NAND gets 1200 cycle warranty from manufacturer nowadays compared to 10K for the worst NAND flash in 2008.
Trashbytes wrote on 2023-07-16, 01:59:The drive will happily take care of itself for many years so long as you leave some free space for garbage collection and provisioning/leveling, I think 25% of the drive capacity is fine but 50% wouldn't be weird either due to partition limits.
and the only way to let drive know that some space is free without trimming are hacks I described above (zeroing/secure erase, smaller partition, hpa).
