IBM PS/1 and Hard drive detection
Reply 20 of 30, by pentiumspeed
I thought the 2121 used non-standard hard drive pinout or different connector? Or is it really IDE interface?
Cheers,
Great Northern aka Canada.
Reply 21 of 30, by DoutorHouse
It's regular ide but the floppy drive is just like the one from the 2011
Reply 22 of 30, by Ryccardo
Some people on vcfed are working on an XTA SSD (both standard XTA = Tandy/Olivetti/Commodore/Segate A-X, and the incompatible IBM PS/1&2 types) 😀
But there's still quite a bit of work left to do, with current knowledge a working HDD is needed and it will be cloned exactly including dead sectors
Reply 23 of 30, by theruler
Ryccardo wrote on 2023-07-29, 19:50:
That's a very promising news! could you pleas e link the discussion?
I've followed the spanish user nestor that did some serious mod on the PS/1.
Reply 24 of 30, by theruler
pentiumspeed wrote on 2023-07-29, 17:34:
Cheers,
yes, I own a ps/1 2121 386 also and the mod is straightforword, just put a CF-IDE adapter and the bios will recognize a very convenient 512MB Hard drive.
Reply 25 of 30, by Jo22
Such a thing is always welcome.. ^^
But please keep in mind that AT-Bus, if possible, often is the better alternative;
has better performance (16-bit), more features (IDE auto-detect), has matured over the years etc.
Edit: That being said, I don't mean to discourage anybody working on XT-IDE/8-Bit IDE.
There are occasions were interesting PCs have on-board IDE (8-Bit) and one PC slot or ISA slot.
Here, it would be a waste not to try to make use of that on-board interface. ^^
Reply 26 of 30, by wierd_w
fjk61011 wrote on 2014-04-12, 11:34:
I got the following from Vintage-computers:
I put a 512 MB Disk On Module IDE flash drive in my PS/1 Model 2121 (the 386SX version of the original weirdo proprietary form factor) and it worked perfectly fine -- I didn't even need to change any of the Setup options. The PS/1 automatically detected it and I was able to FDISK and FORMAT it without any problems.
The PS/1 Model 2011 (286 based), however, uses the same proprietary 8-bit "IDE-XT" interface as the PS/2 Models 25 and 30 (8086), which only works with a limited number of drives, usually 20 or 30 MB. It does not work with standard ATA / IDE-AT hard drives.
It MIGHT however, work with a CompactFlash module on an adapter! Those (fairly frequently) have the 8bit IO mode needed!
Reply 28 of 30, by pentiumspeed
theruler wrote on 2023-07-30, 09:03:
Cheers,
Please cite the information about creating IDE adapter so I could find and read on this?
Cheers,
Reply 29 of 30, by theruler
pentiumspeed wrote on 2023-07-30, 13:40:
Cheers,
Cheers,
Persdico Compact Flash CF To 3.5 Female 40 Pin IDE Bootable Adapter Converter Card Standard IDE Interface True-IDE Mode https://amzn.eu/d/bFufS9c
The ide interface on the 2121 is standard
