Reply 49960 of 56730, by Trashbytes
Bought these two ATi beauties, a Radeon 7200 DDR 64 and a Radeon 9100 DDR 128. The 128Mb 9100 is rather unusual as it appears to be a Crucial model . .even has the Crucial sticker on the back, wonder what they changed if anything. Im also curious as to what drugs ATI was smoking .. why is the 9200 and 9250 such a huge downgrade ? ...were TMUs expensive to put on GPU dies that they cut them in half ?
The attachment Radeon 7200 64 DDR.jpg is no longer available
The attachment Radeon 7200 Back.jpg is no longer available
The attachment Radeon 9100 128 DDR.jpg is no longer available
The attachment 9100 DDR Back.jpg is no longer available
Bought them along with two other parts which Ill have to throw in a second post.
Reply 49961 of 56730, by Trashbytes
Part 2
To go with the two ATi cards above I also bought a very clean Iwill BD100 Plus BX board and a P3 500 CPU, the whole kit is heading to the Lian Li PC 10 case I bought last month.
The attachment Iwill BD100 Plus.jpg is no longer available
The attachment P3 500.jpg is no longer available
The attachment Lian Li PC10.jpg is no longer available
The attachment Lian Li (2).jpg is no longer available
Might do a build post about it, not sure yet as the post Im sure will take more time to edit and format that the actual build 🤣.
Reply 49962 of 56730, by Tiido
appiah4 wrote on 2023-08-01, 14:44:
Yeah I already have a WaveRider 32+, pretty great card if you don't count the 37KB TSR required to use the onboard wavetable 😅
TSR is only needed on the card with WaveFront chipset which lacks a CPU to do MIDI processing (like AWE32 for example). Ones with the Samsung one (like on that photo) or its rebranded Aztech version don't need any TSR as those chips have internal MIDI processor in them.
Reply 49963 of 56730, by appiah4
Tiido wrote on 2023-08-02, 11:51:
Mine is the ICS WaveFront chipset.. On the plus side, it has a very pleasant 2MB sample vs the 1MB sample on the Samsung ones. On the negative side, it's not very feasible to use for games.. I haven't tried loading that TSR high TBH, but I'm not sure it'd be very easy to do so. Maybe with QEMM etc?
Reply 49964 of 56730, by DerBaum
..rebranded Aztech version...
Its interesting that they sometimes rebrand chips and sometimes not.
I had a look at my model and its a rebranded one.
The attachment MMSN852Front.jpg is no longer available
FCKGW-RHQQ2
Reply 49965 of 56730, by Karbist
I bought these 2 Asrock combo boards listed as not working,
The attachment Asrock.jpg is no longer available
K8 combo just needed new caps on cpu vrm and new sata connectors,
vrm caps on P4 combo was already replaced by someone and they were backwards, probably he got fooled by the markings on the pcb, also 2 mosfets on 1.5v rail were dead.
board was struggling to post with any cpu higher than 3.0Ghz, so I added 4 polymer caps near cpu socket where asrock didn't bother to solder and that fixed the issue.
Reply 49966 of 56730, by Trashbytes
Karbist wrote on 2023-08-02, 14:24:
I bought these 2 Asrock combo boards listed as not working, […]
Looks like the P4 board has broken ram sockets .. unless they are meant to be like that .. I wouldn't think so though.
Checked the Asrock site and yeah they are broken, do they still work like that ? would seem like the ram stick wouldn't be held in well enough.
Reply 49967 of 56730, by Karbist
Trashbytes wrote on 2023-08-02, 14:37:
yeah one end of 2 ram slots are broken but they work fine, I probably cut 2 ends of ram slot if I find similar one and glue it to these ones, not gonna bother replacing them.
Reply 49968 of 56730, by ElectroSoldier
TheAbandonwareGuy wrote on 2023-08-01, 23:48:
shamino wrote on 2023-08-01, 23:10:
ElectroSoldier wrote on 2023-08-01, 12:16:
They released this in 2002?
Black/silver wasnt a thing until for a couple of years, at least not on the mainstream.
It was cards like this that got the maufacturers to start making cases you could see into. Not the other way around.
It's a shame that AGP cards are installed upside down, though, so even with a window the interesting side of fancy video cards are hidden.
They didn't even fix that with PCI Express, which kind of surprised me. The only reason cards got flipped in the first place was so they could have a shared slot position between ISA and PCI.
I mean TBF there is reverse ATX like what Dell used for some of their mid 2000s designs, but that creates a whole slew of new problems.
But even then the cards were designed so as to be upside down.
My Precision 690 is BTX.
Even with the cards mounted so the front side is up the cards is upside down, the GTX text on the card is orientated so the motherboard is down, but Im not looking at it from the motherboard.
The only time fancy looking PCI cards make sense is when in a desktop PC case with a window in the side. Because thats the only time the card is the right way up when youre looking at it.
Its only in recent years case manufacturers have realised this and mount video cards on PCIe headers away from the motherboard infront of the window.
Reply 49969 of 56730, by oh2ftu
GF4200ti-8x
HD3650
HD5870
HD6870
Damn wife caught me. All those ATI are surplus for me, can't test them as they are PCIe. And I don't have a PCIe-capable test set - nor do I now have the option to build one ...
Might not tell her I'm looking for two cases atm.. This shit got out of hand.
Reply 49970 of 56730, by Trashbytes
Karbist wrote on 2023-08-02, 14:56:
They are awesome boards, glad you have them working again!
Reply 49971 of 56730, by rkurbatov
Tseng ET6000 with its strange MRAM (of 1.25MB each module, 2.5 in total).
Another non-working ET6000 - if broken and not fixable it will be salvaged for the RAM to have 4.5MB on the first one.
Aaaand - boxed Matrox Rainbow Runner studio - MPEG encoder for my Matrox Millenium II. This is going to be part of a glorious Pentium Pro build.
486: ECS UM486 VLB, 256kb cache, i486 DX2/66, 8MB RAM, Trident TGUI9440AGi VLB 1MB, Pro Audio Spectrum 16, FDD 3.5, ZIP 100 ATA
PII: Asus P2B, Pentium II 400MHz, 512MB RAM, Trident 9750 AGP 4MB, Voodoo2 SLI, MonsterSound MX300
Reply 49972 of 56730, by KungfuPancake
Bought a Diamond Viper V770 for P3 build I'm planning right now. 30€ plus shipping, not an amazing price but I guess that's the status quo right now.
The attachment IMG_0236.jpg is no longer available
Also picked up a Pentium MMX 233 today, for the extra low price of free - bad photos/description and untested, but I'm not complaining. Had to drive a bit, but the sun was shining and the top was down, so I declare that a win.
The attachment IMG_0235.jpg is no longer available
Reply 49973 of 56730, by shamino
Trashbytes wrote on 2023-08-02, 09:55:
I vaguely remember the days when Crucial was advertising video cards on their web site. I've never actually seen one though. Cool card.
Reply 49974 of 56730, by HanSolo
rkurbatov wrote on 2023-08-02, 16:43:
It's not that strange when you think about it: at 1280x1024@16 you need exactly 2.5 MB
Reply 49975 of 56730, by Trashbytes
Bought two ISA sound cards for my PIII Slot 1 build
Sound Blaster Pro 2 CT1600
The attachment Sound Blaster Pro 2.jpg is no longer available
Awe64
The attachment AWE64.jpg is no longer available
Going to set them up to work together, Ill use the AWE64 for windows and late DOS games and the SB Pro2 for earlier Pure DOS gaming, I believe both cards should be just fine with a 500Mhz CPU, I don't remember either being speed affected. I wanted a AWE64 Gold 4390 but ...prices for that card are not great and even at 200 USD I cant justify the cost when the 4380 is only 50 bucks and I have a compatible Simmcomm for it. No idea why AWE64 Gold prices still remain so high, its pretty silly.
Also have a pair of 12Mb Diamond Monster II Voodoo2 cards that dont have a home yet so they may end up in this build paired with the 9100 or 7200.
Hmmm Just realised I also have a Diamond MX300 not in a PC yet ...wonder if this build can support 3 sound cards...leaving the AWE64 for just late DOS stuff and the MX300 for Windows.
Reply 49976 of 56730, by TheAbandonwareGuy
Picked up two GPUs recently:
Caught a ASUS GeForce FX 5700 256MB (normal version, not LE nor Ultra) right as it was listed for $30. "Working enviroment" pull so we will see how that plays out.
I also bought the "ATI Rage 128 Pro 32MB AGP VGA ATI-128 PRO/ULTRA Vintage Video Graphics Card"
Or as I like to call it: an ATI Radeon X800 GTO (or possibly XL, hard to tell without the cooler).
Paid $20 including shipping untested. Looks like it either had at one point aftermarket cooling, or someone tried to put aftermarket cooling on and gave up. Could be either, I think the mostly likely answer is its been through the eWaste system and someone saw a giant block of aluminum and snagged it. Or the OG owner upgraded and moved their cooling setup forward. The fact it HAD aftermarket cooling tells me it was well cared for at some point, so I am hopeful. The sellers only other listed item is an article of clothing, so thats not much to go on.
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
Reply 49977 of 56730, by rkurbatov
HanSolo wrote on 2023-08-02, 20:58:
That's true. But I've read another explanation that such amount of memory is a result of a memory structure.
Reply 49978 of 56730, by Grzyb
rkurbatov wrote on 2023-08-03, 10:36:
Multibank DRAM allows for chips of capacities other than powers of two, but powers of two were also available.
I've seen MDRAM-based cards with 2, 2.25, 3, and 4 MB.
Kiełbasa smakuje najlepiej, gdy przysmażysz ją laserem!
Reply 49979 of 56730, by Trashbytes
Grzyb wrote on 2023-08-03, 11:35:
Why didnt it catch on ? is it more expensive to produce and program for ?
