First post, by andre_6
Hello everyone,
So I got an OCZ Gladiator cooler that is still sealed in box to use in my Socket 754 Asus K8V-X. The cooler is compatible with socket 754, but its fan is a 4 pin female header, as opposed to the board's 3 pin male header. I can install it, sure, but it will always run at max speeds as we know. I was very surprised OCZ didn't predict this problem or didn't bother mentioning it in the instruction booklet.
I had the simple idea of using a fan controller to act as a bypass, but my fan controller only has a 3 pin male header as opposed to the fan's 4 pin female. I'm reluctant to cut away the fan's extra pin so it fits, as it's somewhat crude as a solution and I don't know if it would even work.
I have tried to find an adapter, being a 4 pin PWM (male----fan) to 3 pin (female----motherboard) adapter/cable, but I only found this in the States, and being from Europe, something from over here or even China would be way more sympathetic customs wise. I'm having a hard time even finding one like this in AliExpress:
https://www.amazon.com/4Pin-3Pin-Standard-Ada … e/dp/B01H0OZC9W
Left some visual aids to avoid confusion. Could you please point me out towards a solution? Thank you as always for your help and replies
Reply 1 of 6, by debs3759
It should fit, it just won't have the PWM pin connected. An adapter wouldn't change that, the 4th pin will be redundant with or without an adapter. The shape of the connector will ensure it fits correctly. You would, as you suggested, need a fan controller to adjust the fan speed, it'll never be automatic on that board.
Reply 2 of 6, by andre_6
debs3759 wrote on 2023-08-03, 19:59:
So do I break the tabs on the Gelid fan controller for example, to fit the 4 pin fan cable in it? Just to be absolutely sure before butchering it, it should work, right?
    294.67 KiB
Reply 3 of 6, by kaputnik
andre_6 wrote on 2023-08-03, 20:22:
You'd have to remove the left side of the male connector to make room for the fan's larger 4 pin connector. The keys on the fan connector are supposed go into the slits.
Reply 4 of 6, by andre_6
kaputnik wrote on 2023-08-03, 20:41:
Thanks, I'd just like some assurances that it will work normally with the fan controller, regulating it to normal/quiet levels
Reply 5 of 6, by debs3759
Or buy a controller that has 4 pins on the male connector. Or the same connection you showed in the original photo.
Reply 6 of 6, by andre_6
debs3759 wrote on 2023-08-03, 21:19:
Thanks a lot everyone ended up cutting the controller's left tab, with a sharp cutter and some basic skill it cuts away quite cleanly. It doesn't look bad at all, especially when connected with the fan. I get a "CPU Fan Error press F1 to continue" at boot but Everest reads it fine and I was able to tweak and find the sweet spot between temperature and acoustics.
Now I have one last hurdle regarding noise, my Sapphire Radeon 2600XT's noisy fan. I removed the fan and checked under both sides' stickers, but no bearing is showing. It's tucked away inside both halves I assume? Is there a way to safely open it so I can put an oil drop in there?
