First post, by matthieu.benoit
Hello,
just wondering if anyone has information about the PD-001 ISA card
http://matthieu.benoit.free.fr/133.htm
I got it long time ago from an electronic surplus, and have still not be able to know for what this card is for
thank you for any hint,
Matthieu
Reply 1 of 6, by matthieu.benoit
here a photo of the same card found with a 80286 Motherboard.
note : 1 bipolar prom is missing.
    1.49 MiB
    PD-001 ISA card associated to a 80286 motherboard
Reply 2 of 6, by Deunan
matthieu.benoit wrote on 2023-07-13, 14:10:
Interesting card. It does not care about the data lines, only address lines A2-A9 which is typical I/O port range on a PC. And seems to only use IOR and IOW signals (plus AEN) as well as CLK and it has some counter chips.
It could be some sort of auxilary address decoder for another card, or some debug card, or perhaps some control card but frankly it would be easier to just have 8255 with simple port decoder in that case and this card even uses PROM chips.
Your best bet would be to try and draw a schematic for it.
Reply 4 of 6, by Horun
Interesting ! Can you take a picture of the back ?
Reply 5 of 6, by matthieu.benoit
sorry for late answer , attached a photo of the solder side,
Matthieu
Horun wrote on 2023-08-08, 02:35:
Reply 6 of 6, by weedeewee
Welp...
If i'm counting it right. no databits are used on this card.
the only pads in use are...
AEN, A2-A9, GND, RESET, +5V, GND, IOW, IOR, CLK, +5V, OSC, GND
and I have no idea what it's use is. 😁
I don't see any way it can deliver data to the computer, though the computer might control the card by selecting the correct addresses.?
Do not ask Why !
