Reply 40 of 90, by SavageKurtain
- Newbie
asdf53 wrote on 2023-09-02, 17:00:These cables are single pole, they have no polarity. Any markings and colors are just a guide to help you connect each pin to it […]
These cables are single pole, they have no polarity. Any markings and colors are just a guide to help you connect each pin to its matching other end. The connector on your motherboard and on your CD drive is L-G-G-R, and the color coding is usually:
Left channel=White
Right channel=Red
Ground=BlackBecause your cables have random colors, you cannot use this color coding, but for functionality, this doesn't matter. It does not matter which side you turn the 2x connectors, they just have to connect each motherboard pin to the corresponding pins on your CD drive.
But... The 2mm header are dual, and they have positive-negative/positive-negative as you have seen, so... If i use them like normal cables the polarity isn't counted? I don't understand, can you please make me a drawing?
I'm... Kind of bad with electronics, my friend.
