First post, by copper
I have this card: https://www.vogonswiki.com/index.php/Intel_8% … 516_LAN_Adapter
I'm trying to use an AT28C64 EEPROM with a boot/option ROM flashed to it in the NIC in my XT.
  • The ROM works fine in an XTIDE card in the XT
  • The ROM works fine in the Intel 8/16 in a 16 bit slot in a 386, even with the card set to 8 bit mode in SOFTSET.EXE
  • The ROM does not work in the Intel 8/16 in the XT, even though the rest of the card works for networking
Nothing appears at the memory region, almost like the chip is not powered. However, when I installed the chip in the wrong location, I got RAM errors on the XT, so the socket is definitely connected in some way.
Has anyone ever gotten this to work in an 8-bit slot? Lots of people say it works but I have only seen pictures of it installed with a boot ROM in a 16-bit slot. Is there some other EEPROM, maybe a 32 pin one, that would work, or something like connecting the +5v on the 16 bit region of the card?
Reply 1 of 6, by Horun
What starting address did you set for the option ROM ? C800 is the first start address space after video space...
Reply 2 of 6, by copper
Horun wrote on 2023-09-03, 15:46:
I tried c800, D200, and several other addresses. The card and chip do work in the 386 at the configured address.
Reply 3 of 6, by Horun
Ok, the Intel 8/16 defaults to port 300, do you have anything else that could be at that port address ?? Yes others have gotten it to work in an XT...
(see this)
Reply 4 of 6, by copper
Horun wrote on 2023-09-03, 16:00:
(see this)
The NIC part of the card works fine. It's only the boot ROM that doesn't work. That example doesn't seem to be using a boot ROM.
Reply 5 of 6, by Horun
Yeah ok. What do you have in the ROM chip ? Maybe the code has an invalid header...
Reply 6 of 6, by copper
Horun wrote on 2023-09-03, 16:34:
ROM chip works fine in the NIC in the 386 as well as in the XTIDE card in the XT; I don't think it's invalid.
