First post, by pshipkov
Revision E
https://theretroweb.com/motherboards/s/ford-lian-agp-ali
My level of interest in SS7 stuff is low, but since this came to me for free decided to give it a spin.
For the purpose converted a K6-2+ 550ACZ to K6-3+.
Also, swapped 2-3 bulged capacitors.
Everything works as expected.
Now the question.
Noticed an unpopulated pads for what appears to be level 2 cache tag.
Soldered one. No observable difference in behavior.
There are few more resistor pads.
Will spend few moments tomorrow with the multimeter and see what comes out of it.
At the same time there are pictures of different revisions of the motherboard with the chip installed, but they have the resistor pads unpopulated as well.
Figured i should ask around first if there is tribal knowledge about that stuff, before get quick with the soldering iron.
Any hints ?
