First post, by noapparentfunction
Good afternoon,
This is my first post on this forum, I appreciate any knowledge or guidance in advance.
I just found a Quantex PC from the mid 90s, looks like it was equipped with a Pentium II. It seems pretty large with 4 bays and a floppy drive, I am assuming it's a full ATX tower.
Before I try to work on it, I realize that I have no idea where to find a new shell/side panel/plates for a tower like this. The fact that I don't even know what it's called does not help either. Short of purchasing a different (and expensive) old PC to use as a donor I am a bit stumped on where to begin.
Are modern ATX panels compatible, if I were to buy a new white case? I have attached a photo of the tower.
Have a nice day!
The attachment PXL_20230905_125557958.jpg is no longer available
Reply 1 of 3, by mmx_91
AFAIK, no they are specific and nornally not interchangeable. It also looks that it's a very early ATX case as the lateral panel design is similar to AT ones. Good luck!
Reply 2 of 3, by Warlord
If it was mine, knowing that I would never find the shell in the wild. I would buy some sheet metal and bend my own to fit the case and spray paint it white. Of course I wouldn't be able to replicate all of the tabs that hold it on. But I bet I could do a good enough job that if its just sitting on a desk or a floor, it would be good enough.
I could also wood grain the outside instead of painting it like LGR 486 and It would just look custom.
Reply 3 of 3, by HanSolo
There may be some that can be exchanged but usually that's not the case (no pun intended 😀 ).
Is it really so hard to find cheap ATX cases where you live?
