AGP slot replacement
First post, by supercordo
Hello,
Does anyone know the part number for an AGP pro universal slot. The slot on my motherboard needs to be replaced and i cant seem to find one.
Thanks.
Reply 1 of 5, by Horun
Curious which motherboard. Have seen AGP 2.0/3.0 slots on ebay which are good for 4x/8x or 2x cards that support 1.5v for cheap. Will try to dig out my one board with Universal but doubt there is a Foxconn number on it (they made most of the AGP slots back then). If all else if me would get a AGP 2.0/3.0 slot as would never use a 8x capable board for the old 1x/2x 3.3 v cards anyway... just my opinion...
added: why do you need to replace it ?
Reply 2 of 5, by BitWrangler
If this Digikey link works, there's several out of stock obsolete part numbers you can search elsewhere... https://www.digikey.ca/en/products/filter/edg … X3FFq5EBhGtm4oA
Reply 4 of 5, by supercordo
Horun wrote on 2023-10-08, 02:36:
Pins inside the slot are damaged and corroded. It a Asus ktv-t slot A. If all else fails I'll just install a universal slot and not an agp pro universal slot.
