Reply 1400 of 1502, by Horun
- l33t++
Original Opens perfectly fine in UltraISO and ImgBurn and Win7 built in image burner. Properties: ISO9660/Juliet. Mode2/Form1/2352.
The problem IMHO for proper "mounting" as a basic ISO is it should be a Mode1/2048. Hence the possible need for a CUE using certain image loaders that are not designed/smart enough to fully read the properties.
Just MHO ;p
