Reply 50780 of 58436, by Kahenraz
I am also guilty of reversing a 3.5" floppy cable, and there was no damage. I've never reversed a 5.25" floppy connector. Aren't those card edges keyed?
Reply 50781 of 58436, by DerBaum
Kahenraz wrote on 2023-11-02, 19:52:
The exact thing that happened: i tried to connect a 3 1/2 drive to the same cable and that was reversed.
From that moment on the 5 1/4 drive stopped working properly.
FCKGW-RHQQ2
Reply 50782 of 58436, by zwrr
amadeus777999 wrote on 2023-11-02, 14:00:
zwrr wrote on 2023-11-02, 03:43:
Got these today: 1. Matrox Millennium II, 8MB of WRAM is integrated on board. 2.MSI MS-4131G, 128K L2 cache installed,The locati […]
Got these today:
2.MSI MS-4131G, 128K L2 cache installed,The location of the CPU socket is peculiar.
Nice one - I had quite a few from these.
At first I couldn't believe that these really carried 8MiB.
Yes, we have seen too many onboard integrated 4MB, or 8MB Millennium II with an expansion board, but with an integrated 8MB onboard, it is very special and I believe it can achieve 16MB with an expansion board.
Pentium MMX233, Zida TX98-3D, 64MB, Riva 128, Aztech Waverider Pro 32-3D, HardMPU-wt
K6-III+550, FIC VA-503+, 256MB, Voodoo3 2000, Creative AWE32, HardMPU-wt
Tualatin-1.4G, QDI A10BM, 512MB, G400, Voodoo2 SLI, Creative AWE64
Reply 50783 of 58436, by CPU Galaxy
Madowax wrote on 2019-06-07, 08:54:
Bought these (retro) hardware today […]
Well, I just managed to get the bigger sister of the Winner 1000...
ELSA WINNER 2000 TwinBus (4MB VRAM S3 928 EISA/ISA with 170Mhz Ramdac)
Could you please upload a BIOS dump of this card?
Reply 50784 of 58436, by ChrisK
DerBaum wrote on 2023-11-02, 20:24:
Well , if the new one works I wouldn't touch it.
My experience with dead floppy drives is: when they are dead leave them as is. You can only do more damage (to other drives).
Sad but true.
Besides that: I've never seen such a nice and colorful PCB. It really looks like a piece of art (at least from the picture). How the hell are all those resistors and capacitors mounted? They look like inserted in unplated through holes.
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
Reply 50785 of 58436, by stef80
Acquired 2 of those ... looks like HP branded Asus p2b-d variant ? (HP NetServer E60).
The attachment HP_slot1.jpg is no longer available
The attachment HP_slot1_back.jpg is no longer available
Both boot up fine, extensive testing needed. Very basic AMI bios.
Reply 50786 of 58436, by appiah4
I've never had a reversed 3.5" cable damage anything, it always results in an always on LED on the drive activity light and a complete misdetection of the drive. Reverse plugging a 5.25" cable is kind of difficult as they are supposed to be keyed on one edge. That said, I HAVE seen cables with edge connectors that were not keyed, not to mention that you could plug in the motherboard end of the cable in reverse..
Reply 50787 of 58436, by AlessandroB
I whis to connect all my IBM to just one monitor, keyboard and mouse…
Reply 50788 of 58436, by AlessandroB
Reply 50789 of 58436, by AlessandroB
Reply 50790 of 58436, by AlessandroB
Reply 50791 of 58436, by amadeus777999
zwrr wrote on 2023-11-02, 23:30:
Got these today:
16 would be cool - with a huge CRT it may be nice to see... I do not know the maximum resolution the MMII supports though... maybe 1600x1200x32 with two pages.
Reply 50792 of 58436, by acl
stef80 wrote on 2023-11-03, 07:53:
Acquired 2 of those ... looks like HP branded Asus p2b-d variant ? HP_slot1.jpg HP_slot1_back.jpg […]
Last year i bought an HP Netserver lp1000r
Dual 1Ghz Coppermine. It was very cheap. 30€ shipped !
I was surprised to see that it was actually an Asus board inside.
https://theretroweb.com/motherboards/s/asus-cur-dlsr
The HP bios was very limited and i was able to flash the original ASUS one without any issue.
Can worth a try if you have two boards.
If the flashing fails, you can reflash the old bios from the second board by hotswapping the rom.
Reply 50793 of 58436, by stef80
Have TL866 programmer and BIOS is socketed, so no problem there. But I can't find the original Asus model 😉.
Reply 50794 of 58436, by devius
I have one with 8MB as well, so they can't be that rare 😆 If you're curious about the benefits of having 16MB on a Millennium II check out: Matrox Millennium II 16MB - exists? If so, why?
Reply 50795 of 58436, by Meatball
I had no plans to ever buy this board, but since I stumbled into some of the last AGP cards released (7800 GS and HD 4650), I figured I might as well pick up one of the last AGP boards to go along with them - the 775Dual-VSTA. An I/O Shield, 2GB of DDR2, and an Intel Core2 E7600 were also included. The RAM has since been swapped out with Corsair Xtreme XMS2 PC2-6400 4-4-4-12@350MHz Dominator PC2-8500 5-5-5-15. Initially, it would not run with two sticks of the Dominator Rev. 1.2 - the board would only POST with a single stick installed. However, I also have a matching set of 2GB Rev. 1.0, and the board is now working fine with them.
I also picked up a GeForce 2 Ti, which is being tested in the board at the moment before moving on to the 7800 GS, HD 4650, and once it arrives, a 550 Ti.
Reply 50796 of 58436, by MrKsoft
Based on a single low res photo and barely a description more than "old PC" I grabbed this system off Facebook Marketplace. Looked like a 286 or 386, and with the monitor it seemed like it was worth saving.
I think I made a good gamble: It had a nice little surprise inside, a Cyrix 486DLC-33. 😀
Other than that, it's an Acer ISA486GLi motherboard with a couple floppy drives, two Maxtor IDE drives (131MB and 540MB) and didn't really have much in terms of cards installed, an Oak OTI-077 being the most "exciting". This "Axiom" VGA monitor seems unremarkable too, can't find much record of it existing online, but I do like having more serviceable smaller CRTs for older systems like this that won't be pushing high resolutions.
Haven't quite decided if I will hold on to this or not, but will probably at least keep the 486DLC.
The OPL Archive - Preserving MS-DOS music in a unified format!
Reply 50797 of 58436, by ciornyi
got 2x servers with tyan s2462 dual socket A boards for 25$
DOS: 166mmx/16mb/Y719/S3virge
DOS/95: PII333/128mb/AWE64/TNT2M64
Win98: P3 900/256mb/SB live/3dfx V3
Win Me: Athlon 1333/256mb/Audigy2/Geforce 2 GTS
Win XP: E8500/4096mb/SB X-fi/Quadro fx 4500
Reply 50798 of 58436, by Nexxen
MrKsoft wrote on 2023-11-05, 00:16:
Based on a single low res photo and barely a description more than "old PC" I grabbed this system off Facebook Marketplace. Loo […]
When I saw it I thought it was the same a s one I got last week. Coincidences... 😀
I'll try the BIOS to see if it POSTs with your BIOS version.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 50799 of 58436, by BitWrangler
A few members here feel that DX2/66 are overrated and fast 386 slow 486 are the sweetspot for late 80s into early 90s DOS gaming, and then jump to pentium for the Doom+ FPS and fast action stuff. So that would be a good reason to keep this one together and use it.
