Reply 50800 of 57996, by Shponglefan
Recently acquired a rare Tandy 1000 TL/3.
The attachment Tandy TL3 Case.jpg is no longer available
System is in really nice shape, just a little dusty on the inside and no visible rust. Did a brief power on test and seems to boot up just fine.
At some point I'll probably give it a complete teardown to clean out the disk drive, inspect the motherboard and replace the PSU fan.
The attachment Tandy TL3 Inside.jpg is no longer available
With this TL/3 in my possession, my Tandy TL trinity is finally complete. 😁
The attachment Tandy TL Trinity.jpg is no longer available
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 50801 of 57996, by BitWrangler
Cool, I had one bookmarked on Marketplace that was out near Peterborough somewhere, is that the one? Though I need to get the tandy virus like I need another hole in my head 🤣. But always thought they were "cute" kinda.
Reply 50802 of 57996, by Shponglefan
BitWrangler wrote on 2023-11-05, 15:55:
This one came from the U.S.
They're fun machines, one of the better DOS gaming platforms of the mid-80s. 😀
Reply 50803 of 57996, by Kahenraz
Shponglefan wrote on 2023-11-05, 15:35:
Recently acquired a rare Tandy 1000 TL/3. […]
That power supply is huge. What is it rated for?
Reply 50804 of 57996, by TheAbandonwareGuy
Ordered a Viper V330/RIVA 128 AGP.
Received the PCI version. With a heatsink installed none the less.
Not complaining, given the rarity of the PCI version. IIRC John Carmack used one of these as the target for consumer video card performance when optimizing Quake II, as he had one installed in that fancy $10k portable PC he had.
We shall see if it works.
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
Reply 50806 of 57996, by nfraser01
Never mind the trinity, that's a tidy workshop!
Reply 50807 of 57996, by Ensign Nemo
I'm jealous! I recently missed out on a Tandy 1000 EX on marketplace. Came with a Tandy monitor too. Would have made a fun 80s system to play around with. Which one of you guys beat me to it? (-:
Reply 50808 of 57996, by Repo Man11
I'm not going to buy this retro hardware, but for any fellow Vogons in driving distance, this is available. I'd be tempted, but I've decided that I need to downsize to have a lighter load when I move to a less crowded place that I can afford.
Reply 50809 of 57996, by smtkr
capacitors are like new eh? 🤣.
Reply 50810 of 57996, by Nexxen
Repo Man11 wrote on 2023-11-05, 19:19:
Living in California that's what, 2 days of rent at current prices? 🤣
It is tempting though...
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 50811 of 57996, by nfraser01
Does this count? It's got a 486 inside it 😀
Reply 50812 of 57996, by BitWrangler
Do it compute? Things I have seen Cumana's name on include peripherals and graphical terminals, so I am not sure what I'm looking at. Terminal with local removable disk access?? Or actual smol PC
Reply 50813 of 57996, by 3lectr1c
Lucked into a couple nice things locally yesterday for free!
The two coolest items were an IBM 5151 monitor (which unfortunately may be completely dead - that or my Deskpro isn't working with my completely unknown condition MDA that may just be bad as well), and a Nan-Tan FMA8100 "laptop".
The attachment unnamed.jpg is no longer available
The attachment IMG_5430.jpeg is no longer available
Unfortunately, I don't have the proprietary PSU for the Nan-Tan laptop, so I can't test it. Visually it looks good inside though, pulled the clock battery before it could completely explode.
Owner of https://www.macdat.net, the largest vintage laptop documentation resource on the web!
Reply 50814 of 57996, by Trashbytes
BitWrangler wrote on 2023-11-05, 22:46:
Looks like an accelerator card honestly but it might be a CPU on a riser too.
Reply 50816 of 57996, by BitWrangler
3lectr1c wrote on 2023-11-06, 13:34:
Lucked into a couple nice things locally yesterday for free! […]
Those 5151s tended to have "all" the brightness and contrast control in the top 20% of the knob's range (and pots could also be noisy) when they were a mere 15 years old, so you might need to play with the knobs, up to full range in a dark room to see if you are getting anything or not.
Putting volts to the battery connectors is sometimes a good way to see if there's life in old laptops.
Reply 50817 of 57996, by 3lectr1c
I've had the brightness cranked to max, it shows zero signs of life. No high-pitched noise, sounds of a CRT starting, nothing. That's normal behavior however if they don't have a proper MDA signal coming in, and my MDA card is in unknown condition, so my bets are more on that my MDA card is bad or my Deskpro 286 not initializing it than the monitor being COMPLETELY dead.
As for the laptop - unfortunately, it's weird. It did not come with the battery, and I believe that the battery was an external pack that clamped onto the back somewhere. There is no internal battery bay, but it has battery status LEDs on the front. I know some of the other early Nan-Tans did this too. I can't find an obvious battery connector either, so my only guess is that it connected direct to the main power connector, which is a mini-din similar to PS/2 or mac serial. I could definitely find the cable for it, but it would be getting the right pinout that would be a challenge.
Reply 50818 of 57996, by nfraser01
It's an Acorm RiscPC 600 with an ARM CPU and a 486 in the second CPU slot 😀
I lucked out as the battery had only just started leaking so was able to cut it off and clear up the area without there being any damage....
No StrongARM 😀
Reply 50819 of 57996, by BitWrangler
nfraser01 wrote on 2023-11-06, 16:24:
It's an Acorm RiscPC 600 with an ARM CPU and a 486 in the second CPU slot :-) […]
No StrongARM 😀
Oh wild, I guess my chances of coming across one of those are next to zero outside of UK. I guess the earlier Archimedes PC emulator thing needed a hardware lift.
