Netburst: Aiming for the Stars
Reply 180 of 526, by H3nrik V!
supercordo wrote on 2023-11-20, 16:18:
Added a bracket for the Netburst platform for overall scores. Some will like it some will hate it. I dont care.
Your thread, your rules 😎
Reply 181 of 526, by supercordo
Keep Calm and Benchmark ON.
Reply 182 of 526, by 3lectr1c
Can I submit a pitiful score from a Pentium 4M?
Owner of https://www.macdat.net, the largest vintage laptop documentation resource on the web!
Reply 183 of 526, by PcBytes
I might actually come back with one soon enough - P4 2.8GHz, Radeon M10 (Mobility 9600). Desktop chip, socket 478. Will update this post once done.
Reply 184 of 526, by supercordo
3lectr1c wrote on 2023-11-20, 19:33:
Of course!
Reply 185 of 526, by PcBytes
Well, this is the best I could do before GPU started spazzing out, unfortunately.
I would have gone back to redo it with a GPU-Z window attached but considering the power brick was at its limit (this one requires a 6.3A charger and the only one I have is a 4.7A) I figured I should not push my luck...
Specs:
  • ECS Green 736 laptop
  • Pentium 4 2.8GHz Northwood, SL6Z5 (yes, this absolute bricc of a laptop runs on a desktop SL6Z5. No wonders it gets atrociously hot.)
  • 768MB DDR-333 (1x512MB + 1x256MB)
  • 80GB Samsung HDD
  • 15 inch 1440x1050 LCD
  • XP SP3
2003 crashes the GPU on me, 2000 will not even run.
Reply 186 of 526, by 3lectr1c
Here's a completely pointless run on my WinBook X4 (ECS Green550).
CPU - Pentium 4M (Northwood) @2.0Ghz, socket 487 mPGA
GPU - Chipset integrated graphics, SiS 651, SMA VRAM
RAM: 512MB
3DMark 2000 Score: 3172
Now I'm going to go bench my Inspiron 9100, which I suspect will do much better with proper ATI graphics and a full desktop prescott chip inside. I'm curious to see whether it or PCBytes' G736 will do better.
The attachment IMG_5760.jpeg is no longer available
Reply 187 of 526, by 3lectr1c
9100 run is done.
CPU - Pentium 4 (Prescott) @2.80GHz
GPU - ATI Mobility Radeon 9700
RAM - 768MB
3DMark 2001 Score: 9877
Ran at native 1280x800.
Might also bench my ThinkPad T30 at some point.
What about my Pentium D (Presler) desktop? Those are netburst after all.
The attachment IMG_5761.jpeg is no longer available
Reply 188 of 526, by nd22
I have a quite a few Abit motherboards supporting P4. My question is: Cedar mill is allowed or only Willamette/Northwood/Prescott?
Reply 189 of 526, by PcBytes
Personally, I'd say it should be since it's Netburst as well. (actually, everything from Willamette up to Presler should be Netburst architecture, IIRC)
But I'd wait and see what @supercordo has to say.
Reply 190 of 526, by waterbeesje
To everybody who thinks their Williamette system is too slow, remember me.
"Hey, can I come and play with you big guys?"
The attachment IMG_20231121_091322.jpg is no longer available
The attachment IMG_20231121_092208.jpg is no longer available
Yes I know, this board should have a lot more potential and i'm sure it has. However, this comes closest to my computer i had when this was considered modern 😀
Asus P4T
i850 chipset
Socket 423
128MB RDRAM (2x 64MB and 2x terminator)
Massive 1,5GHz Pentium 4
Asus V7100, GeForce 2 MX400 with 32MB
No OC effort 😀
Stuck at 10MHz...
Reply 191 of 526, by supercordo
nd22 wrote on 2023-11-21, 06:48:
All of netburst. Ill make new brackets as the benchmarks come in. With that said, you still need to participate in aiming for the stars. Stock benchmarks will no longer be accepted. Put some effort into overclocking the system.
Reply 192 of 526, by STX
waterbeesje wrote on 2023-11-21, 08:44:
...Asus P4T...No OC effort 😀
supercordo wrote on 2023-11-21, 14:00:
...Stock benchmarks will no longer be accepted. Put some effort into overclocking the system.
Overclocking this board should be easy with CPUFSB. With a little FSB overclocking, you'd qualify for a ranking under supercordo's latest rules, waterbeesje.
Reply 193 of 526, by supercordo
STX wrote on 2023-11-21, 18:55:
The Asus P4T has overclocking options in the bios un less its an HP oem version.
Reply 194 of 526, by 3lectr1c
How does one overclock a laptop I wonder? Would my 9100 even support it? I don't think I should try until I get around to tearing it apart and replacing the thermal paste... and I'm all out of thermal paste...
Reply 195 of 526, by supercordo
3lectr1c wrote on 2023-11-21, 19:13:
The biggest hurdle would be cooling if you could manage to figure out how to overclock it.
Reply 196 of 526, by STX
supercordo wrote on 2023-11-21, 18:58:
Its manual describes options for setting the FSB, Vcore and multiplier. Wow, I didn't know of any Pentium 4 motherboard that allows the multiplier to be changed!
How does one overclock a laptop I wonder? Would my 9100 even support it?...
A few minutes of web searching revealed some clues: The GPU seems overclockable, but the CPU does not seem overclockable because its PLL is not supported by software-based FSB-setting software.
Reply 197 of 526, by PcBytes
To be honest I wouldn't attempt doing a OC on the ECS G736.
It runs hot as it is now - OC-ing on it would likely require radioactive liquid nitrogen cooling 🤣
Reply 198 of 526, by supercordo
STX wrote on 2023-11-21, 19:43:
Its manual describes options for setting the FSB, Vcore and multiplier. Wow, I didn't know of any Pentium 4 motherboard that all […]
You can change it if you have an unlocked P4. Which is very rare. I think Engineering samples were unlocked.
Reply 199 of 526, by waterbeesje
Oh wait, this happened some time I wasn't looking at the rules? Had this page open for a few days, so must have missed it 😮
Reboot is on its way one of these days
Stuck at 10MHz...
