Reply 40 of 148, by rmay635703
- Oldbie
I think the universal ask list is always as follows (due to broken, missing or rare components) reasonable or not.
1. Floppy / HD emulation, physical interface or both
A) USB storage and keyboard mouse solutions
2. Communications, Ethernet, WiFi and methods of easily moving data to the machine or using the machine to access networking directly
A) Modern web, there have been musings (mainly 8-bit micro related) to have a modern web sandboxed on a card with a means of output and control by the vintage machine to simplify in effect using the vintage machine to collect all the files off the web
3) Audio and soundcards, everybody loves sound
4) Exotic memory expansions including EMS 4 and locating ram into the upper 384k
5) video cards and sync adapters, some just want VGA/HDMI, some want legacy, some want some sort of combination EGA to HDMI or VGA on a mono screen. I personally have VGA converted to 15khz RGB+S (like an Amiga)
The above are most every exotic project I’ve seen mused or attempted.
Despite your view that ISA is only PC/XT related I can easily see much more modern machines making use of a specialty ISA card if it gives them the audio or virtual floppy they want
