First post, by zwrr
I have a BEK P407 motherboard, it suddenly doesn't boot properly, the screen doesn't show anything after the power is turned on, the beep is very strange, I tried to change the graphics card, memory, etc., nothing changes.
Can someone please tell me the meaning of this beep code?
BEK P407 beep code.mp3
322.5 KiB
18 downloads
486DLC-40, 386-VC-H, 32MB, GD5429, ES1868F
X5-133, HIPPO-15, 32MB, Riva 128, ES1868F
5x86-120GP, SYL8884, 32MB, Trio64V+, ES1868F
Pentium MMX-233, T2P4, 128MB, TNT2, SB16
Tualatin-1.4G, 694X, 512MB, G400, Voodoo2, SB AWE32
Reply 1 of 4, by Horun
Sounds like: One long two short then a failure buzz-beep.
Typically a Video error beep code but I would check your PSU to make sure it is providing proper volts before doing anything else -> assuming it all was working properly and re-try the original parts again.
Reply 3 of 4, by zwrr
Horun wrote on 2023-12-05, 02:50:
I tried multiple ISA and PCI graphics cards, Trident 8900C, 9000i, GD5422, S3 Trio 64V+, etc., and nothing changed.
Regarding the PSU, I also replaced it and can confirm that the PSU works fine on other motherboards.
Reply 4 of 4, by zwrr
NHVintage wrote on 2023-12-05, 03:11:
I don't suppose your cmos battery is dying? If you unplug it from power for a little while do you lose your bios settings?
I tried removing the CR2032 battery and nothing changed, black screen and alarm and that's it.
