First post, by zuldan
I'm trying to identify these network cards to locate the DOS drivers for them but it's proving to be difficult. For example for card #6, I Googled "EN2000P3" and nothing comes up.
Any help would be greatly appreciated!
406.39 KiB
High res version https://1drv.ms/i/s!ArnHV3_qjaPhg6tjd_mYR4vTDofk5Q?e=iOhn1k
Reply 1 of 4, by chinny22
looks like this is card 5
https://www.vogonswiki.com/index.php/Viglen_E … ergen_PnP_2000A
Clearer pics of each card both front and back will help me I'm struggling to read the numbers on the chips (guess I'm getting old)
part numbers and fccid numbers printed on the card itself also help to ID cards.
Reply 2 of 4, by zuldan
chinny22 wrote on 2023-12-07, 02:49:
looks like this is card 5 https://www.vogonswiki.com/index.php/Viglen_E … ergen_PnP_2000A […]
I've added a high res version to the original post. Than you for looking!
The chips on it compared to the Viglen Ethernet PnP 2000A look identical, just the PCB layout is a bit different.
I'll give these drivers a try http://vogonsdrivers.com/getfile.php?fileid=902&menustate=0
Reply 3 of 4, by chinny22
Card 1
Myson Century Myson MTD900F Series
https://www.driverguide.com/driver/detail.php … driverid=627016
(Select the zip file bit further down the page, not the big download now buttons up the top)
Card 4
Davicom dm9008f?
Bunch of drivers here
https://www.network-drivers.com/companies/287.htm
Reply 4 of 4, by Horun
Card 4 Davicom DM9008 is a PnP card (think they all are) so for DOS you would need to set it up that way (on a board with PnP bios or use a PnP manager app)
http://web.archive.org/web/20050406094815/htt … driver_9008.htm
the drivers do download...
