First post, by songoffall
- Member
I got an IBM Thinkpad T23 with Pentium III-M 1.13GHz, 256Mb IBM/Micron SDRAM, an IBM TravelStar IDE HDD and S3 SuperSavage with 16Mb SGRAM.
Trying to install Windows on her was pretty problematic - the partition table would get corrupted when the Setup program tried to format the drive, but formatting the drive on a Dell I have solved the issue.
The trackpoint is... not dead, but it does not function as expected either. Only moves vertically and jumps a little up or down when touched, but not the way a trackpoint is supposed to work.
It's also... a bit sluggish, especially compared to my Compaq Deskpro 2000 with Pentium II 300MHz.
Upgrading the controller firmware and the BIOS is also impossible, because that would require a charged up battery, and the battery has been dead for a long time.
I would assume this is just the way the Pentium III-M works, except my Dell Latitude C800 with a 850MHz CPU, same amount of RAM and same HDD performs much better.
Am I missing something?
Compaq Deskpro 2000/P2 300MHz/384Mb SDRAM/ESS ES1868F/Aureal Vortex 2
Asus A7N8X-VM400/AMD Athlon XP 2ooo+/512Mb DDR DRAM/GeForce 4 MX440/Creative Audigy 2
Asus P5Q Pro/Core2 Quad Q9400/2Gb DDR2/GeForce 8800GT/Creative X-Fi
