SERIAL MOUSE NOT WORKING
Reply 21 of 43, by Law212
Is the cable to the motherboard connected correctly. On my mobo the red is on the opposite side, and on this P1 build I first had it the way you did and my mouse wouldnt work either.
Reply 25 of 43, by plumbnebula5741
I've bought this one
https://www.ebay.it/itm/314530756137?hash=ite … ItemCondition=4
Since it says it was pulled from an older pc, perhaps it might work? I'll post an update when i get it
Reply 26 of 43, by PC@LIVE
So, with a simple change to the port connections, you can make the mouse work, without the need for other cables or ISA cards, it's as they suggested quite simple, currently you have the cable connected like this:
1 2 3 4 5
6 7 8 9
Unplug everything except cable 1, then reconnect so they look like this:
1 3 5 7 9
2 4 6 8
That's all, this is the only way it works, if you want you can repeat the work on the second serial cable.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
Reply 28 of 43, by Timucin
To clarify the things, we make the modification on the port that we connect our mouse in right? Apparently we cannot change anything with the other header that we connect directly to the comport. I have more than 8 cables none of them worked. ISA card with Comport didn't work either.
    93.84 KiB
    83.33 KiB
    77.38 KiB
    256.76 KiB
    346.36 KiB
Reply 29 of 43, by PC@LIVE
Timucin wrote on 2023-12-17, 19:54:
To clarify the things, we make the modification on the port that we connect our mouse in right? Apparently we cannot change anyt […]
So I explained it in my previous post, you need to change the wires from 2 to 9, that is, desolder them and re-solder them so that the odd ones are aligned, and the even ones too, to understand the row of five must have odd wires, while in that of four, the even wires must be soldered to it.
If you have any doubts, just see the diagram I inserted previously.
If, however, you have the ports with the wires connected linearly, i.e. the row of five with wires from 1 to 5, and the row of four with wires from 6 to 9, in the Soyo 5BT5 (and also in other MB), any whatever you connect to it won't work, ditto for the parallel port, that too must have the same connection diagram.
Reply 30 of 43, by PC@LIVE
View image
Reply 31 of 43, by Timucin
checked my cables and one of them is this, I bought it on Aliexpress:
https://tr.aliexpress.com/item/10050049055113 … ayAdapt=glo2tur
I think this cable is what you mention. But this cable doesn't work either.
Reply 32 of 43, by Kouwes
I’ve had exactly the same problem with a 486 board. Known working serial mouse not working.
The original cables were gone so I just bought a very cheap (NOS!) ISA card with only COM1 and 2 - set the jumpers for the serial connectors on the board to OFF and the mouse came to life.
Reply 33 of 43, by Timucin
I have this ISA Com port and I wonder whether would that work on windows 95? I tried it but it didn't show any sign of life for my mouse. And yes I changed IRQ settings first. I don't know whether I need extra drivers or settings like jumpers since my mobo has no jumpers for comports
    233.69 KiB
    202.56 KiB
    248.81 KiB
    244.17 KiB
Reply 34 of 43, by weedeewee
Timucin wrote on 2023-12-18, 13:51:
I wish you would stay within your own thread in stead of usurping this one, but here we are.
If all the hardware is working correctly then that isa card should allow serial port functionality on your mainboard given the jumpers are set correctly and your mainboard is configured correctly.
Do not ask Why !
Reply 35 of 43, by plumbnebula5741
assuming you tried the isa card connected and not the port, maybe you need to disable intergrated serial (if it does have)
Reply 36 of 43, by plumbnebula5741
not togo out the topic but i just installed my AT psu with the button wiring scheme that came (tho i had to replug them) im not testing it till tomorrow, but what could happen if its plugged in the wrong order, like do you get a smoke show?
Reply 38 of 43, by plumbnebula5741
yeah, im following and in the diagram in the psu it should all be ok but i am unsure, i already had a pc explode and i dont want it to repeat
