Reply 20 of 25, by weedeewee
DerBaum wrote on 2024-01-15, 15:16:Is there a special reason you want the pcmcia layer in between IDE and a CF card? You can use CF cards as Harddrives with just a […]
jnemo2004 wrote on 2024-01-15, 14:53:I want to use this adapter card (ISA to PCMCIA) with an adapter PCMCIA to Compact Flash.
You can use CF cards as Harddrives with just a small passive 10 euro adapter.
There are even brackets for the rear of the pc already made for accepting cf cards and a direct ide connection...
hotswappable.
Do not ask Why !
