Reply 20 of 47, by rasz_pl
noshutdown wrote on 2014-01-17, 09:37:
who is the isa speed king in windows with 2d acceleration?
To answer that question we must define "doing what". Moving windows? Rendering fonts in Word documents with tons of text?
For example when it came to games it looks like it didnt matter much Re: Your opinion on the ATi Rage IIC and Rage Pro
elianda wrote on 2014-01-18, 12:15:
You should better ask, what about Win NT or NT4, since 2D is implemented there much faster than in Win9x. Typically a factor of 5 to 10.
Highly doubt that. GUI was very polished in w95, up to hand optimized assembly where it made sense. One way someone could make above conclusion would be using driver employing hardware blitting on NT, but falling back to software path on W9x.
Reply 21 of 47, by rmay635703
Cornerstones ISA cards seem to have the most acceleration features, that and other high end fixed frequency cards
Reply 22 of 47, by kingcake
rasz_pl wrote on 2024-01-31, 05:37:
Yep. Microsoft went through great lengths to provide their own accelerated/direct draw Win95 drivers for legacy video cards that were all but abandoned by vendors.
IIRC, lots of the accelerated functions, like line drawing, made huge differences in synthetic graphic drawing benchmarks, but the real world speedup wasn't that impressive.
Reply 23 of 47, by MikeSG
There's multiple factors to a good windows ISA card. Resolution, LCD clarity, performance...
One of the last VGA cards from Chips & Tech supported all interfaces including ISA, VLB, PCI, Mobile. The F65545.
https://vgamuseum.info/index.php/comments/ite … nologies-f65545
Speciality was in LCD clarity and windows performance, at the expense of low video memory - 1MB. Chips & Tech claiming +80% performance using optimised drivers verses standard software methods.
Other high performance cards... Tsengs W32i 64-bit memory interleave claims +70% performance.
Reply 25 of 47, by Marco
Ha, you are really often underlining this in the forum I just discovered 😀
No honestly, I would summarize the situation about ISA GDI Accelerators like this:
- There are kind of common "opinions" or "favorites" in the forum like W32i, S3 928, ATI Mach64, GD5434/5429 for GDI for ISA
- Finally there are no (or I couldnt find them) real benchmarks available showing the GDI 2D performance of ISA cards under e.g. W95 via Winbench, Wintach, Wintune oder whatever
- It is also unclear if there is any difference in the GDI support in dependency to the power of the CPU used. Compareable to #Riva128 performance vs Voodoo performance on slow OR fast CPU systems
Regards
1) VLSI SCAMP 311 | 386SX25@TI486SXLC2-50@63 | 16MB | CL-GD5434 | CT2830| SCC-1 | MT32 | WDC160GB/7200/8MB | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | LAPC-I
Reply 27 of 47, by douglar
Marco wrote on 2024-02-01, 09:55:
What bench mark would you like to see?
lolo799 wrote on 2024-02-01, 10:21:
kixs wrote on 2024-02-01, 09:16:
The fastest ISA card in Windows is of course ATI Mach64 VRAM.
What about an S3 Trio 64V card?
I've never seen an ISA version of the S3 Trio. This might be S3's best ISA card: https://www.vgamuseum.info/index.php/companie … /345-s3-p86c801
Reply 29 of 47, by Anonymous Coward
As far as I know, trio32/64 doesn’t support ISA natively. Are you sure the card wasn’t cardbus?
The best s3 should be the 928. The 801 was their slowest.
Reply 30 of 47, by lolo799
Anonymous Coward wrote on 2024-02-01, 14:12:
It was definitely not cardbus, you can see the benchmarks results in the link in my signature.
Reply 31 of 47, by kixs
Ha, you are really often underlining this in the forum I just discovered :) […]
Regards
I guess you mean me 😉
Mach64 VRAM is really on another level with performance compared even to VLB cards like S3 805.
I have benchmarks made on PcChips M919 - ISA, VLB and PCI cards Trio64, ET6000 for reference - Win95 OSR2.1 + Winbench 3.11 + WinTach 1.0 + usual DOS apps/games.
I've probably tested around 30+ ISA/VLB cards. Also where possible 1MB vs 2MB to see memory interleaving performance boost if available.
If you ask me. Best overall ISA card is based on Cirrus Logic GD5434 chipset. As it's very fast in Windows and probably fastest in DOS. Mach64 VRAM is fastest in Windows but average in DOS. The average performance in DOS also applies to VLB and PCI version.
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 32 of 47, by MikeSG
lolo799 wrote on 2024-02-01, 14:19:
From what I understand about the PCMCIA Trio32/64, is it can use VLB in 8/16/32 bit transfer mode. Ie multiple transfers... and although the PCMCIA bus is 16-bit ISA, you can technically convert it to a slow version of VLB.
The Trio 32/64 and 64V were more integrated, so I guess there's cost savings.
Reply 33 of 47, by Marco
kixs wrote on 2024-02-01, 14:55:
Any possibility to share your bench results? Would really appreciate.
Regards
Reply 34 of 47, by douglar
lolo799 wrote on 2024-02-01, 14:08:
douglar wrote on 2024-02-01, 12:43:
There's a pcmcia one, I benchmarked it some years ago.
https://en.wikipedia.org/wiki/S3_Trio
Motherboard interface: ISA, VLB, PCI, AGP (Trio3D only)
So if that's correct, I guess it was possible. I just can't find the cards.
Reply 35 of 47, by lolo799
douglar wrote on 2024-02-01, 15:49:
https://en.wikipedia.org/wiki/S3_Trio Motherboard interface: ISA, VLB, PCI, AGP (Trio3D only) […]
Apart from the pcmcia one, which you can use in an isa slot with an isa/pcmcia interface, there is no Trio64 ISA card available.
Models using the 16bits C-bus interface on PC-98 do exist.
Reply 36 of 47, by kingcake
Agree 100%. The Cirrus Logic cards also have excellent image quality/compatibility with LCD monitors.
Reply 37 of 47, by Marco
Thanks for asking. At the end I don’t really care about a certain specific bench but I’m interested in any bench that is comparing 2D acceleration performance with isa cards. So Wintach, winbench, I would appreciate anything 😀
Reply 39 of 47, by douglar
kixs wrote on 2024-02-03, 09:43:
A snippet as I want to redo all the benchmarks... […]
file.php?mode=view&id=184373
Very nice start.
You are using 1/4 ISA divider, yes? Does the screen refresh affect numbers? Are you going to use a 1MB cache stick when you retest?
