Reply 51700 of 58451, by justin1985
Another random eBay SFF purchase arrived - a "Kiosk PC KP3 - B72" - which I found in a search looking around for badly described PCs. The tiny size really appealed to me - basically the same size as two normal 5.25" drives side by side!
This model is the Celeron M 1.5Ghz, and it comes with a 512Mb SODIMM of DDR-266 RAM, a 40Gb 2.5" HDD, and a slim DVD-ROM (both on the secondary IDE channel, which has a 44-pin header).
I've never seen a legacy PC like this quite so small! Clearly it was intended for public kiosks - the manual talks about optional wall mounting kits etc., but although there is some grime under the CPU fan, it is relatively clean inside, so can't have seen that much use. (In fact I think most of the dark visible dust came from the wool packaging the seller had used - it looked like the compostable wool insulation you get in some mail order meat / meal deliveries). It also seems interesting that it came with a not just the power brick but manual and driver CD - but the seller seemed to be private and mainly dealing in homewares, so I'm intrigued where it came from and what it had been doing for the last 20 years ... someone had clearly been looking after it. The HDD is unfortunately wiped and not even partitioned.
(I can't find the manual anywhere online at all, so I'll happily scan it to add to theRetroWeb if wanted?)
The Intel i852 chipset looks like it has official Win98 iGPU drivers, so it seems like a great candidate to replace my VIA EPIA as a super compact Win98 system ...
It looks like there might JUST be enough room to fit an ESS Solo-1 into the PCI riser for DOS sound (max size 124.5x81mm, according to manual) - is that likely to play nicely with the i852/ICH4 chipset combination? Or would SBEMU be a better bet?
What kind of reputation does the Celeron M have? Pentium M was pretty well regarded, I think? The Intel Extreme Graphics 2 on the i852 is going to be pretty poor though?
