fsinan wrote on 2024-02-07, 09:32:
Will try the Cyrix 5x86-100GP on it but could not found any manual for this board. Anybody out there have a source of info?
https://theretroweb.com/motherboards/s/u-board-jk-042e
First I would start testing, if everything works as expected with the Amd X5-133, so 133MHz and to verify if the L1 is working in WB mode.
Second, then it would be good, when you provide better pictures of the board, the ones on retroweb are hard to read. So somebody can upload it to retroweb then.
Changing the CPU to Cx5x86 should be the last step.
If 1) was successful, you need just to replace the CPU. It will probably then run correctly, but only at 66MHz, because the AM5x86 interprets the 2x jumper as 4x. So to run the Cyrix at 100MHz only one jumper has to be removed.
Do you actually have this board in your hands, or was this more a theorectical thread/question?
