First post, by 1ST1
Hello, there was a software/hardware called The ZippA to boot from parallel port ZIP drives even on XT class computers. There used to be two versions:
1. with modified MBR on the local harddisk load some function and then the system can continue to boot from the ZIP drive before an OS is loaded from harddisk
2. a little 8 BIT ISA card with the BIOS code to boot from parallel port ZIP drive
What could be found until now:
https://brianlivingston.com/windowmanager/arc … st/bl060997.htm
https://web.archive.org/web/20070407045456/ht … s.com/zppa.html
https://web.archive.org/web/20011227213205/ht … bin/ZPPA099.ZIP (evaluation version of the version 1)
53.91 KiB
ROM BIOS card
Question: Does anybody has preserved the content of this BIOS chip?
Idea: Plug the BIOS on the empty boot ROM socket of a network card...
Reply 1 of 1, by weedeewee
Neat.
Checking the archive does list all the zip boot options to require a 386 or higher.
Do not ask Why !
