First post, by retrotechrestoration
I'm working on trying to get a 20Mb CM-3426 MFM drive from an Acer PC-500+ II working. The original MFM controller card (WD1002A-WX1) in the Acer is fried, so I replaced it with a WDXT-GEN2. It spins up fine but attempting to low level format it results in an "Error 80" immediately upon starting the format. The drive and it's controller board are clean, with no obvious damaged components. I may do some thermal imaging on it to verify that. Meanwhile I dumped the firmware from the drive controller board eprom, but it seems to be garbage. There are no obvious text strings in it. I know this is a long shot, but if anyone has a dump of this eeprom, I'd love to try reflashing it.
Here's a link to my dump of the eprom.
https://www.retrotechrestoration.com/download … 6-drive-rom.bin
Thanks
Reply 1 of 13, by weedeewee
FYI,
There's no reason the rom from a hard drive would contain any text strings whatsoever.
It does not talk to the user directly, the rom on the interface card does that.
When you say format, which format do you mean? DOS format or low-level format ?
Do not ask Why !
Reply 2 of 13, by retrotechrestoration
As I mentioned, the error was while trying to low level format it.
Ya, the rom is prolly fine. It had its original protective label and was facing against the bottom of the drive. Would just be nice to have something to compare it to.
weedeewee wrote on 2024-03-01, 20:23:
FYI, There's no reason the rom from a hard drive would contain any text strings whatsoever. It does not talk to the user direc […]
FYI,
Reply 3 of 13, by BitWrangler
It's also possible the EPROM is unique to the drive and contains a factory bad block list and calibration info..... though that is a relatively "modern" feature.
Reply 4 of 13, by weedeewee
retrotechrestoration wrote on 2024-03-03, 00:45:
FYI,
Dangit, sorry, missed that.
Looking at the photo of the eprom on the microcontroller & the datasheet... are you sure the eprom is in the correct location ?
the datasheet makes me think that the eprom should be filling the right most sockets and leaving the left ones open on the photo, since that's where the data pins are according to the datasheet.
though thinking about it... that wouldn't make sense, your hard disc controller would 've complained about the disk during bootup...
Do not ask Why !
Reply 5 of 13, by retrotechrestoration
weedeewee wrote on 2024-03-03, 08:18:
Dangit, sorry, missed that. […]
FYI,
Thanks for the reply. I'll look at that adapter more closely and check...I assume you're referring to the eprom datasheet? The BIOS does spit out a 1701 error on boot which is a pretty generic code unfortunately.
Reply 6 of 13, by weedeewee
retrotechrestoration wrote on 2024-03-03, 18:03:
No, the HD68P01V07 to which the eprom is mounted. https://pdf1.alldatasheet.com/datasheet-pdf/d … HI/HD68P01.html Looking at your first photo, the eprom should be shifted completely to the right, if i'm reading the datasheet correctly. The way it is connected now is guaranteed to deliver the microcontroller, the HD68P01, incorrect programming.
Do not ask Why !
Reply 7 of 13, by retrotechrestoration
weedeewee wrote on 2024-03-03, 18:46:
Oooh, neat...I've never seen one of those before!
Reply 9 of 13, by retrotechrestoration
SUCCESS!
I moved the eprom into it's correct position...no go. I found a replacement WD1002A controller on ebay...no go. I tried different cables...and success! The drive works perfectly and has a ton of productivity software on it!
I'll make sure to image it immediately just in case. Thanks for everyone's help!
    967.71 KiB
    Computin' like it's 1990 again!
Reply 10 of 13, by weedeewee
I'm so glad that the eprom survived !
Enjoy ! who would've guessed the cables after the eprom.
does the old controller work with the new cables ? better try it after you backed up the data on the drive 😀
Do not ask Why !
Reply 11 of 13, by retrotechrestoration
weedeewee wrote on 2024-03-11, 20:42:
Technically the cable that work are the originals that came with the machine. When I was testing the different controller card I was using the IBM cables it had come with.
The original WD1002A card is definitely shorted somewhere. The machine wouldn't even power up with it plugged in. I had a similar problem with a different card in the Franklin. Thankfully the power supply was smart enough to detect that and nothing else got damaged. 😀
Reply 12 of 13, by BitWrangler
News headline like: Test Trauma: Tantalum Terror Taunts Tech
Reply 13 of 13, by retrotechrestoration
BitWrangler wrote on 2024-03-12, 02:26:
Lol, wouldn't be the first time. I fixed a Compaq Portable 386 by replacing a single tantalum.
Btw, this Acer was last used by a property appraisers office in Georgia in July of 1995. Still had all it's documents, forms and spreadsheets.
That HMenu system is kinda slick. It automatically reads the root directory and updates the menu on each boot. Any commands put in an heyn.bat in each subdirectory will be run when a menu item is selected. It also has a cute little resident virus protection program.
