Reply 40 of 52, by weedeewee
FYI, https://theretroweb.com/motherboards/s/auva-c … mputer-npm16-a0
or one of the others that looks so awfully similar.
though the numbers underneath the stickers do seem to match.
Do not ask Why !
Reply 41 of 52, by boggit
weedeewee wrote on 2024-03-07, 16:25:
Yup, I was just looking at that entry. Seems like the nearest match so far. Especially like picture 4 of 14 on that page.
The difference seems to be that I lack a JP7 jumper - but then again, so do many of the motherboards on the pictures on that link (and, just like the mobos displayed on the images, mine is obviously not 22x22 cm).
Reply 42 of 52, by boggit
Fiddling around with the motherboard and removing it from the case, I did manage to pierce the skin of my left index finger, resulting in some blood on the PCB and some traces:
Using a Q-tip, I did manage to get it all off (at least from what I can see):
Am I good or should I be worried about this?
Reply 43 of 52, by boggit
Some pictures of the motherboard:
Back
Jumpers one and two. Also proof that Bank 1 is the one closest to the edge of the mobo.
Front overview
Close-up of the upper jumpers.
RAM sockets. No funny business here, it seems.
Reply 44 of 52, by boggit
Okay, I re-installed the motherboard into the case and booted it up. HIMEM.SYS now works? I don't know what I did or how I did it, but it works.
Thanks to all of you who followed me along on this strange journey.
Reply 45 of 52, by weedeewee
boggit wrote on 2024-03-07, 17:42:
The gods accepted your blood offering.
(just kidding)
Do not ask Why !
Reply 47 of 52, by mkarcher
boggit wrote on 2024-03-07, 14:06:
UPDATE: Okay, this is quite a head-scratcher. I switched out the two 4MB SIMM cards, replacing them with two 1MB SIMMs from my 286 mobo (as one can not, according the jumper manuals of all the likely motherboard suspects listed by BitWrangler [here], run 4MB using just one 4MB SIMM card).
Same A20 error as before and - here is the kicker - with /M:1, DOS reports the same unreliability error on the exact same address (00100000h).
The address you quote is the start of the XMS - so this is just another symptom of a non-functional A20 address line. As you get the same error with two different sets of memory modules, faulty memory is very unlikely to be the cause.
I guess there was an actual short between the A20 gate control line and ground, making the A20 gate permanently closed. Cleaning the board, or inserting it in a slightly different position, preventing a possible short at an installation bolt probably cleared that short, so A20 control now works fine.
Reply 48 of 52, by weedeewee
boggit wrote on 2024-03-07, 18:27:
Yes. […]
weedeewee wrote on 2024-03-07, 18:20:
Yes.
(just kidding)
I'm not.
that pleases them.
anyway. enjoy !
and if it somehow re-occurs, it's likely a bad contact. Somewhere on the board. or that what mkarcher stated.
Do not ask Why !
Reply 49 of 52, by BitWrangler
Glad it's working now, yeah defoprobablymaybe a short or something cleared, or just mild flexion of the KBC socket rubbed off some oxide and let metal touch, or the blood sacrifice did it.
The "take it all apart and put it back together again" thing is almost as good as "turn it off and on again" sometimes.
Reply 52 of 52, by douglar
boggit wrote on 2024-03-07, 16:48:
The joke between me & my friends back in the days when there was only sharp edged cases and through hole components was that the computer was not going to work until it received a blood sacrifice.
