First post, by Grosvince
Hello !
I've got this DX2 CPU for a while but unfortunately it has a heatsink glued on it.
I only have a 486 rig from Tulip Computers in which I have tested the CPU, but the post screen is very simple with no information about CPU. Furthermore this computer didnt have a classic bios setup program (you need to run a program from dos, which I don't have yet).
Is there any chance that a chip guru could tell me what is this cpu with the backside markings only ? Is it and Intel, AMD, what Is the rated frequency ?
Vincent
Reply 1 of 18, by debs3759
It's an Intel, but I can't tell from the marking which model or speed. Is there no label on the edge of the heatsink?
Reply 2 of 18, by BitWrangler
I am not real expert at this, but wanna say that rounder corners on the cover make it an intel, by the fact it's not so close to the pins, smaller size, it's a die shrink so DX2, has a couple of key pins missing vs common Dx2 so maybe overdrive??? Mainly just guessing though.
Reply 4 of 18, by Shponglefan
If you have a box cutter and a mallet, these heatsinks aren't too difficult to remove.
You just insert the box cutter blade between the heatsink and CPU. Then gently tap it until the heatsink comes off.
I've done this successfully with a few stubborn heatsinks.
    738.12 KiB
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 7 of 18, by debs3759
Oops!
Reply 9 of 18, by BitWrangler
Merde alors, we didn't want that to happen.
Everyone check the calibration stickers on your mallets are up to date, don't want it giving you an 11 when you asked for a 3.
Reply 10 of 18, by PD2JK
Well... at least the pins weren't bent.
The one in the bottom left area included, it only tipped.
Reply 11 of 18, by Shponglefan
BitWrangler wrote on 2024-03-23, 20:08:
I said gently tap it! Gently!
Reply 13 of 18, by megatron-uk
That's the kind of force my wife would have used if someone mentioned there was a slight possibility of a live spider under the heatsink....
https://www.target-earth.net
Reply 14 of 18, by luckybob
its supposed to be TAPPY TAP TAP..
Not beat the shit out of it like it fucked your girlfriend...
At least it was only a DX2-66. I guess.
Reply 15 of 18, by Trashbytes
luckybob wrote on 2024-03-24, 02:19:
It should have kept its pins outta the wrong socket.
Reply 16 of 18, by Sphere478
I have two dx4 with that bottom.
Btw, next time, put flame on the heatsink. It will pop right off when hot
Sphere's PCB projects.
Reply 17 of 18, by CoffeeOne
PD2JK wrote on 2024-03-23, 22:06:
https://www.youtube.com/watch?v=UijhbHvxWrA
Reply 18 of 18, by Dan386DX
90s PC: IBM 6x86 MX 233MHz. TNT2 M64. 256MB/1GB.
Boring modern PC: i7-12700, RX 7800XT. 32GB/1TB.
Fixer upper project: NEC Powermate 486SX/25. 16MB/400MB.
