ISA Cards & Devices Requiring -5V
Reply 20 of 32, by QBiN
Just as an FYI... I have found the following two PSU's currently being sold that still support a -5V line on the ATX 20-pin connector. I'm sure there are others out there. This was just a quick pass through NewEgg to see what was available and somewhat cheap. You should be able to find these at your favorite online computer shops without too much trouble.
StarTech ATXPOWER300 300W ATX Power Supply
RAIDMAX RX-380K 380W ATX12V Power Supply EDIT: DO NOT BUY. NEWEGG PHOTO IS OLD. NO LONGER SUPPORTS -5V.
EDIT: Update to available -5V supplies.
Reply 22 of 32, by QBiN
By definition, all AT power supplies will include the -5V line. But it's good to know that they are still available. (I actually have one of those star tech AT PSU's as a spare / testbed PSU).
Reply 23 of 32, by ibm5155
OFF:
would that StarTech PSU work on this config?
-Pentium MMX 233MHz
-128mb sdram
-3DFX VOODOO 3000 AGP
-Maxi Sound Game Theater 64 (ISA)
-Ethernet PCI + USB2.0 PCI
-80GB HDD
-DVD-ROM
turbo display (I did some tricky connection, so I Took the usb card and used his internal usb to give the display energy since my motherboard doesn't support it '-'
well, that's all 😀
I have a good PSU on this device, it has like 10 years or more that I have it, it worked just fine on a pentium 3 1GHz, but the problem is:
1)ATX (Power on/Off on this case is useless '-')
2)220v only (So I always need a really big transform to use the computer '-')
But at least it has a cool feature on that atx psu, It can stay on by one second without energy thanks to a big transformer or battery inside of it 😳
Reply 24 of 32, by QBiN
ibm5155 wrote:
OFF:
I found an older thread where you were talking about some of this. Since you have an AT case and an AT power supply currently. I would recommend staying with that configuration, personally.
If you think your PSU is flaky. You could buy the StarTech AT PSU new. I think that's a better option than ATX, even if your motherboard can technically accept an ATX PSU.
Reply 25 of 32, by ibm5155
The AT psu is now gone, since months of research I concluded that the AT PSU was the cause of all my problens.
So for now I'm only using the ATX PSU since it's the only thing I have for now '-', the motherboard is good, it support ATX and AT connection...
Fun fact: I discovered that for somehow, If I had a flash drive pluged in usb 2.0 board, I noted a huge performance drop (27fps on quake 2, 40fps on quake 2 without the flash drive), but for some reason, the same flash drive on the internal usb 1.1 wouldn't cause any fps drop (and others usb things wouldn't actually touch the fps)...
1 year of hard research was actually good, I ended up making a kind of ms-dos text engine 😁
Reply 27 of 32, by Jinxter
Since pin B5 is not connected on Sound Blaster Pro 2 (CT1600) that should suggest that this card does not need -5v
https://www.vogonswiki.com/index.php/File:Cre … 2_underside.jpg
Check out my YouTube channel: Retro Erik https://www.youtube.com/c/RetroErik
My collection: https://retro.hageseter.com
Reply 29 of 32, by digger
scroeffie wrote on 2020-12-02, 10:52:
is nobody selling those at to atx adapters anymore bought 2 of them like 2 years ago with -5 and a dummy load works perfect in my p1 and p3
the seller stopt making them
If you don't mind a somewhat more expensive (but fancier and safer) solution, search for the "ATX2AT" project.
Reply 30 of 32, by stealthjoe
I just got a YMF719 which seems to have the 5th pin and I am not sure if it requires -5V for proper operation. Please see the images below. Could someone please let me know if this requires -5V? If so I may have to return this card as I don't have an AT PSU.
1.59 MiB
1.81 MiB
Intel 845GEBV2, Pentium 4 2.4 Ghz, Geforce FX5600 256MB, 512MB RAM, 160GB HDD, Sound Blaster Live! SB0100 - Win 98/XP
Reply 31 of 32, by TheMobRules
stealthjoe wrote on 2024-03-28, 07:12:
No, that card does not require -5V. The pad is there, yes, but there are no traces coming out of it.
Reply 32 of 32, by stealthjoe
TheMobRules wrote on 2024-03-28, 08:03:
Thanks a ton for confirming! Feeling at ease now 😊
