Reply 52621 of 60069, by Dan386DX
I really appreciate all the replies regarding the FX 5500, I won't quote everone individually but I will run some benchmarks on the P3 Coppermine tonight and let you know it's looking. I read that some, if not most FX 5500s ran on a 128-bit bus, where as the 5200 was almost exclusively 64-bit despite sharing the same core. Of course, mine is further limited by being the PCI version.
FWIW, I bought this GPU planning to use it with a 6x86MX PR300, it's looking increasingly like that's a terrible idea 🤣
90s PC: IBM 6x86 120Mhz. 128MB/6GB. ATI Rage Pro 3D.
Boring modern PC: R9 3900X, RX 7800XT. 32GB/1TB.
Fixer upper project: NEC Powermate 486SX/25. 16MB/400MB.
Reply 52622 of 60069, by Kahenraz
I think that the FX 5500 is exclusively 128-bit. I'm just spitballing, but I can't think of any examples that I have encountered otherwise.
Reply 52623 of 60069, by acl
Dan386DX wrote on 2024-04-16, 19:09:
Not sure if the PCI bottlenecks that much.
I tested a much later system last week and played with a late PCI GPU.
It was a P4 Presscott 3.8 with a PCI HD 4350.
HL2 runs on very high + AA4x at 1024x768 (30+ fps)
I pushed it a little with Crysis. Which ran at 800x600 on low in the 15 to 20-something fps (dropping a lot during fights)
(Edit : and the games were running from a USB ke 😃)
The attachment IMG-20240412-WA0001.jpeg is no longer available
The attachment IMG-20240412-WA0003.jpeg is no longer available
Testing it in a faster system could show some improvements over the P3. (And driver version is key, as always)
Reply 52624 of 60069, by berenyi_kft
Some cards that I got today 😀
Sapphire Radeon HD 3850 AGP with an orange label instead of the more common blue one(all the other cards I've seen had blue labels)
The attachment HD3850AGP.jpg is no longer available
Canopus SPECTRA 7400 GeForce 256 DDR
The attachment Canopus_SPECTRA_7400.jpg is no longer available
AOpen Aeolus GeForce4 Ti4200 8X
The attachment GeForce4_Ti4200_8X.jpg is no longer available
And last, but most definitely not least..
AOpen Aeolus GeForce FX5950 Ultra
The attachment GeForce_FX5950_Ultra.jpg is no longer available
The attachment 59502.jpg is no longer available
Motherboard: ASRock 775i65G rev 3.0
CPU: Intel Pentium Dual Core E5800 3.2GHZ
RAM: Corsair CMX1024-3200C2PRO DDR 400MHz CL2 1GB x 2
GPU: Sapphire ATI Radeon HD 3850 AGP
Sound: Audigy 2 ZS
CRT: Iiyama Vision Master Pro 454 HM903DT 19'' 1920x1440 85Hz
Reply 52625 of 60069, by devius
Got a PCIe XFX GeForce 6800 Xtreme 256MB. I only realized it was missing a cover over most of the heatsink when I got home after buying it.
This is actually my first dedicated PCIe graphics card ever.
The attachment IMG_6710.JPG is no longer available
Retro Coisas no YouTube
Reply 52626 of 60069, by berenyi_kft
While I'm pretty sure that most FX 5500 cards have a 128bit memory interface, there are a few exceptions, this is true for most FX 5200 cards having a 64bit memory interface as well, both cards can come with either config, I believe even the FX 5700 LE cards have a 64bit memory interface.. although those cards don't suffer as much because they at least utilise their bandwidth more efficiently
Sound: Audigy 2 ZS
Reply 52627 of 60069, by Dan386DX
Okay, so after forcing an earlier driver to work with the FX 5500, I managed to get 20% more in 3DMark 2001. Driver 45.23 works with Windows 98 but doesn't support FX 5500 without a little tweaking.
With a Pentium III 500e, one of the more modest Coppermine P3s, I was able to get reasonable 3D performance in Swat 3, but Project IGI still chugs. Now the latter game I remember playing on my S370 Celeron using onboard graphics in 2001, and at the time I didn't notice performance to be an issue at all - could just be that I was more used to bad frame rates then, but I'm almost certain the experience I'm getting with the FX is worse than that was.
@acl - thank you for the detailed post, there is an interesting guide on Phil's channel where he compares FX5500 AGP vs PCI, worth checking out. I think you're right though, and I'm bottlenecking the hell out of the card.
Would you guys say that running this card with 6x86 233MHz is a pointless endeavour? Could anybody suggest a better-fitting PCI card?
Anyway, here's the benchmarks, at stock vs the modded 45.23 driver.
...and now I will stop hijacking this thread 😀
Reply 52628 of 60069, by Repo Man11
Kahenraz wrote on 2024-04-16, 19:30:
Unfortunately this isn't true. I had a hard time finding a 128 bit one (a PCI one anyway), and one that I purchased that was advertised as such turned out to be 64 bit.
Reply 52629 of 60069, by Trashbytes
Repo Man11 wrote on 2024-04-17, 01:08:
Likely a rebadged 5200 with a bios mod to make it a 5500, since they are essentially the same silicon with the only real difference being that the OG 5500 was the full 128bit bus with higher clocks, they even share the same horrible feature cuts and same even more shit DX9 performance.
AI is inevitable, there is nothing you can do to stop it, no Ironman snap to save you from the Basilisk.
Reply 52630 of 60069, by zuldan
This little beauty arrived today. I'll need to replace 4 caps but she still works fine. I thought the Geforce 2 Ti's were 64MB but this one is showing itself as 128MB?
The attachment G1.jpg is no longer available
The attachment G2.jpg is no longer available
The attachment G3.jpg is no longer available
The attachment G4.jpg is no longer available
Reply 52631 of 60069, by Kahenraz
I've never heard of a 128MB GeForce 2-anything. Even Quadro 2s were only ever 64MB. Very curious.
Reply 52632 of 60069, by BitWrangler
MSI had a short spate of gussied up models, would be a Starforce Titanium VIVO or something
Reply 52633 of 60069, by Trashbytes
Kahenraz wrote on 2024-04-17, 03:55:
https://www.pcstats.com/articles/915/index.html
Its one of the early 1.1 versions with 5ns ram . .likely that program is reading it wrong as it should be 64Mb according to MSI specs, could the GF2 adress 128Mb of DDR ? ...would be very weird as we didn't see 128Mb till the GF3 TI cards.
Reply 52634 of 60069, by BetaC
Today I picked up a dinky little guy.
The attachment IMG_3265.jpg is no longer available
I mean just look at him. Small PCB, weird feature connector popping outta his head. And he doesn't even fit in to the system he's meant to be put in to.
The attachment IMG_3266.jpg is no longer available
I mean, just look at those hanging fingers...
As you can tell by the joking, It's not actually a bad thing to have. This is an ATi VGA Wonder Basic, which just so happens to support being inside an 8-Bit machine like my XT. Lo and behold, I can finally use something actually readable to do things on said XT instead of the smeary 5151.
The attachment IMG_3262.jpg is no longer available
And hey, it's compatible with most modes it seems.
The attachment IMG_3269.jpg is no longer available
I certainly can't complain.
Reply 52635 of 60069, by zuldan
Trashbytes wrote on 2024-04-17, 04:07:
This site mentions “Max memory 128MB”. https://www.vgamuseum.info/index.php/cpu/item … dia-geforce2-ti
I’ll run some other software packages and see what they report.
Reply 52636 of 60069, by Trashbytes
zuldan wrote on 2024-04-17, 06:10:
If it is 128Mb then thats a very nice GPU to have around ! totally worth replacing all the caps on it and perhaps finding some small heat sinks for the memory.
Reply 52637 of 60069, by zuldan
Trashbytes wrote on 2024-04-17, 06:15:
I really hope it’s 128mb. I grabbed it for $30 plus delivery. I’m surprised you didn’t take it before me 😉
Reply 52638 of 60069, by Trashbytes
zuldan wrote on 2024-04-17, 07:12:
I saw it and realised I dont need anymore repair projects and I already have 3 GF2 cards.
Reply 52639 of 60069, by zuldan
Trashbytes wrote on 2024-04-17, 07:20:
Sounds like you have too many cards. I think you should sell me your GeForce 4 Ti4600 for $30 😉 🤣
