Reply 80 of 86, by maxtherabbit
kixs wrote on 2023-07-08, 19:21:
Since I was replacing a blown up Tantalum cap on one wavetable card today and had some free time, I took the chance to do the o […]
Since I was replacing a blown up Tantalum cap on one wavetable card today and had some free time, I took the chance to do the oscillator removal on one 286 board and replacing it with a socket - this was in the plans for many years 🤣
Originally running at 20MHz with soldered Harris 80286-20, I tested it up to 27MHz. Screenshot at 25Mhz as a teaser. Will do another thread for "Kixs's 286 to the Max Too" soon 😁
what chipset?
Reply 81 of 86, by iPonRMA
kixs wrote on 2023-07-08, 06:49:
iPonRMA wrote on 2023-07-05, 19:11:
I know its an old thread, but i just built my first version of "FAST 286" project a few weeks ago. Still at 25MHz...
Nice build 😀
But some specs with more photos would be nice 😁
Thanks. The motherboard has a "PC-CHIPS3" chipset (or something with this sticker on it), 25MHz Harris CPU, Cyrix 287XL+ FPU, 4MB SIMM RAM, Tseng ET4000W32i videocard, 1.2MB & 1.44MB FDD, Seagate 520MB HDD, Creative Sound Blaster Pro2.
Here is a video with some benchmarks and games:
https://www.youtube.com/watch?v=c2TBeuVWuQA
I will try other mobos soon with FSB increasing.
Reply 82 of 86, by kixs
maxtherabbit wrote on 2023-07-09, 01:04:
what chipset?
More info here:
Reply 83 of 86, by DarthSun
The Bench_XT package is excellent, and I managed to test Wolf3D on Madness machine.
R3800X @4GHz def, 2C/2T/NV7900GS/SB0060/sound on/SBEmu/FVid LFB/WC on :
67.46 KiB
Machine in SpeedSys :
139.05 KiB
Reply 84 of 86, by MikeSG
Just wanted to add some interesting stats from a 386sx 25MHz board I've been testing.
Chipset: Chips & Tech F82C836 B-25
CPU: Intel 386sx-20 at 25MHz
RAM: 8MB 60ns, 8 SIMMs
VGA: Trident 8900D-R, 0WS, 1996 dated Siemens FP RAM
The F82C836 was an "A", but the "B-25" models are available to buy new so I soldered the B-25 on. No performance difference but may be able to clock higher.
The F82C836 is a 0WS 25MHz-max chipset with hidden refresh.
ISA Bus 10MHz:
3DBench: 8.2
Landmark VGA: 4777
ISA Bus 12.5MHz:
3DBench: 8.4
Landmark VGA: 5957
Linear 1.25x increase for Landmark, but only 1.02x increase for 3dBench.
Also tested a CL-GD5429 (1WS). Landmark VGA score was ~4770 at 12.5Mhz, the same as the 0WS Trident at 10Mhz.
CacheChk RAM speed was 11.1MB/s.
Reply 85 of 86, by Deunan
MikeSG wrote on 2024-04-19, 10:32:
Your Trident is -R variant, which apparently means reduced (in terms of complexity) for cost optimization. Not sure how it compares to non-R 8900D but I do know you need 1MiB of VRAM on 8900D to get to to full 32-bit internal bus speed. 0WS setting is important too but it's that 32-bit internal bus that mostly sets apart 8900D and other, slower cards.
Reply 86 of 86, by MikeSG
This is the card. There are less components, however BIOS/screen overlay says 1MB on boot.
RAM is two "256k x 16bit". 16ms refresh cycle. 2x longer than 1991 DRAM (mb81c4256a-70p).
https://html.alldatasheet.com/html-pdf/45237/ … 14171BJ-50.html
8900D's are also 48MHz.
A list of 0-wait state video cards ranked by performance would be interesting.. obviously the Tseng W32i is at the top.
Eg. Landmark Video (chr/ms):
Tseng ET4000 W32i: 8057 (bus MHz?)
Trident 8900D-R: 5957 (12.5Mhz)
Cirrus Logic 5420...
